- Thank you received: 6
Which exhaust to buy?
- fordtruck
I don't plan on making too many mods. Probably dyna-s ignition and coils and maybe individual air filter instead of the factory air box.
Thanks a bunch
'77 KZ1000-MTC 1075 kit. Stage 1 port
- Bluemeanie
- Thank you received: 14
Yes, you will have to re-jet for 4/1 pipe and definitaly for pods. I prefer the stock air box with a K&N filter myself. I've heard it can be tough jetting with the pods as there are many variables such as side wind, low pressure area cruising, water effect, etc.
Good luck and let us know how it goes!
- fordtruck
I've heard similar things about the air pods as you. I might just stick to the factory air box and put in a K&N filter.
Thanks again. Any and all advice is most welcome!
- madkawltd900
- RetroRiceRocketRider
- Thank you received: 29
If you're planning on using the OE airbox, some exhaust systems still require minor rejetting for "peak performance".
Systems like Mac and Jardine however tout that they can be used w/out any rejetting provided the OE airbox is being used, (I'm running a Mac 4-into-1 on my KZ650 with the OE airbox, and it runs just fine w/out rejetting).
If you plan on running pods (individual air filters), then regardless of the brand of exhaust you definately WILL need to rejet the carbs.
Rejetting for pods isn't always easy but can be done, and for most people it takes just a few tries to get the jetting just right.
Another thing to consider is that some exhaust systems require removal of the center stand to even be able to mount their system to your bike.
This set-up also blocks access to the oil filter and oil drain bolt, so the exhaust will neeed to be removed each time you want to change your oil and filter.
Along with the PITA factor this poses, IMHO having the exhaust that close to the oil pan can't possibly be good for the oil temp. :S
Kerker (now owned and sold through Super Trapp IIRC):
Very nice sound, good quality finish, and easy to install. Not an easy system to find for some bike models however.
V&H:
Similar to Kerker in sound, quality and easy of install.
Still being manufactured, so systems for most models can still be had.
Jardine:
Decent sound and quality. But I've heard some people complain that the mounting for the muffler is off slightly, and requires some "tweaking" for a good, solid alignment.
Mac:
Although nice sounding, a step below the Jardine in fit and finish. The benefit is that they. make them for a lot of models, and are probably the least costly system available.
There were quite a few other systems made years ago (Yoshimura, RC engineering, Bassani, etc) for your bike, but unfortunately are no longer being manufactured.
If you're able to locate one of them in either NOS or decent used condition, then I'd suggest snatching it up if it doesn't become to pricey!
The earlier Yosh systems are side-by-side comparable to the Kerker IMO.
RC engineering systems are similar in fit and finish as the Kerker, yet have diff jetting requirements and a slightly diff sound to them.
The Bassani is one butt-ugly system, but has a sound like no other system out there! And if properly rejetted for, will offer a noticeable performance increase. Removal of center stand to mount it and removal of exhaust required for oil/filter change are it's only drawbacks.
If I could find a Bassani for my bike, I'd consider selling/renting my wife to be able to fund it!
:whistle: :lol:
- chetriply
The Kerker is an incredible pipe. The Jardine has some of the best fit and finish on the market. The Jardine is louder but it still sounds good, not annoying.
I can get you the Jardine $355.00 Blk. $399.00 Chrome
The Kerker: $499.00 Chrome $399.00 Blk
V&H 275.00 chrome. Plus shipping, no tax. Those are my everyday prices. I'm not trying to steal anyones business, just saying what my prices are.
- vixweb
Shreveport,Louisiana
\'80 KZ1000 A4
I am currently restoring a '80 KZ1000 A4 That has a 4 into 2 system(factory?)- How significant is the difference between 4-2 vs. 4-1 ? What about sound?
The most noticeable between a 4-into-2 and a 4-into-1 will be the weight difference. Usually somewhere in the 15~20 pound weight savings range.
Plus a lot of the 4-into-1 systems offer increased ground clearance over stock 4-into-2 systems, so you'll likely drag the pegs during aggressive cornering before the exhaust even comes close to the ground.
And the sound will all depend on the brand of pipe, as well as what baffle ("street" baffle, "race" baffle, etc.) that it's equipped with.
- Bad Kaw
- Flying Squirell
- Thank you received: 13
Jardine: used to be cheap crap, now it's not, it's decent stuff.
Kerker: Used to be directly associated with Kawasaki, used to be the best, perhaps they're not the best now, but they're still good quality...sometimes they don't fit extremely tight on the bike, but they're still a good header.
Vance and Hines: used to be in-the-hunt for #1...now they'r pure sh*t...avoid the V&H stuff.
Again, just my opinion.
Also, any header you get is going to flow so much better than any KZ exhaust system that I am confident that you should re-jet regardless of whether or not you keep the air-box.
Good luck, keep us posted.
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
- fordtruck
- vixweb
\'80 KZ1000 A4
- madkawltd900
