new rebuilt KZ750 Engine... SMOKING!??
  • Johnny Red
  • Johnny Red's Avatar Topic Author
  • 80 KZ750 H LTD
01 Jan 2008 17:01
#187274
OK I got the bike all rebuilt. and she started right up!
BUT... The engine is smoking a gray/white smoke.
I put on 4 air pods, and a breather filter on the beather case. stock exaust... for now.:)
What could cause the smoking? both pips are smoking.
  • Johnny Red
  • 80 KZ750 H LTD
Re: new rebuilt KZ750 Engine... SMOKING!??
01 Jan 2008 17:08
#187278
Update! Here is a pic of the KZ750 complete!
  • hannah1
  • hannah1's Avatar
01 Jan 2008 20:00
#187309
Maybe still some assembly lubricants or the rings haven't seated yet . The motor looks fantastic , what type of finish have you done ?
Post edited by: hannah1, at: 2008/01/01 23:01
  • bill_wilcox100
  • bill_wilcox100's Avatar
01 Jan 2008 20:26
#187315
Un-combusted oil in exhaust is associated with light coloured smoke.
Could be a valve guide. More likely a bad valve guide seal leaking... if so seals are an easy and cheap fix.
Best of success!
PS
Great looking bike.
Post edited by: bill_wilcox100, at: 2008/01/01 23:36
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
  • saltydog
  • saltydog's Avatar
02 Jan 2008 05:16
#187340
I had this problem with an old MGB, years ago. It had a vacumn operated pcv valve and the diaphragm had a hole in it and it was sucking oil from the crank case. I'm not familiar with your system but maybe something like that could be a possibility?
1981 KZ1000 CSR, 1982 KZ440 ltd, 1972 Honda ct90, 1978 KZ 650
  • saltydog
  • saltydog's Avatar
02 Jan 2008 05:19
#187341
That is a cool looking seat. It's not stock, is it? Where did you get it?
  • Bluemeanie
  • Bluemeanie's Avatar
02 Jan 2008 05:35
#187344
Did you install pistons and rings dry or lube cylinder walls? If you lubed (I do) give it a chance to burn off. ;)
  • BSKZ650
  • BSKZ650's Avatar
02 Jan 2008 05:38
#187345
may need to run it for a bit, you can put a fan in front of the motor and run the rpm up and down to break it in
77 ltd1000, current rider
76 kz900, just waiting
  • trippivot
  • trippivot's Avatar
02 Jan 2008 10:45
#187379
do not worry about pre-break in smoking. get 15-20 minutes on the engine varing the revs not over revving it. change the oil and filter. ride it around like normal .
I had an engine that I re ringed and it took almost 100 miles to quit smoking. the glaze took a bit to scuff off maybe a little synthetic oil,wrong crosshatch angle ??? . I dunno why it took so long to break in. but it eventually did- I knew I had the ring end gaps right and piston to cylinder clearance was correct, so I ran it
  • baldy110
  • baldy110's Avatar
02 Jan 2008 14:50
#187401
Smoking is pretty common on a fresh engine. Break it in and it should stop. DO NOT baby the engine. Run it hard. If you baby it, it will smoke and the rings will not seat properly.
  • hannah1
  • hannah1's Avatar
02 Jan 2008 16:56
#187416
3rd gear , 10 pulls from 30% of redline to redline . That's what my engine builder always said , he built me several fast , long lasting roadrace engines .
  • Johnny Red
  • 80 KZ750 H LTD
03 Jan 2008 08:52
#187490
UPDATE! Thanks for your help! :) .
OK so the engine has stop smoking after riding for about 20 miles. YAAAAAA!
As for the engine paint, I used a aluminum paint for engines.
It only took 3 1/2 weeks to rebuild! So you can do it too!
