new rebuilt KZ750 Engine... SMOKING!??
- Johnny Red
- 80 KZ750 H LTD
BUT... The engine is smoking a gray/white smoke.
I put on 4 air pods, and a breather filter on the beather case. stock exaust... for now.
What could cause the smoking? both pips are smoking.
- Johnny Red
- 80 KZ750 H LTD
- hannah1
Post edited by: hannah1, at: 2008/01/01 23:01
- bill_wilcox100
- Thank you received: 5
Could be a valve guide. More likely a bad valve guide seal leaking... if so seals are an easy and cheap fix.
Best of success!
PS
Great looking bike.
Post edited by: bill_wilcox100, at: 2008/01/01 23:36
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
- saltydog
1981 KZ1000 CSR, 1982 KZ440 ltd, 1972 Honda ct90, 1978 KZ 650
- saltydog
- Bluemeanie
- Thank you received: 14
- BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
- trippivot
- Thank you received: 3
I had an engine that I re ringed and it took almost 100 miles to quit smoking. the glaze took a bit to scuff off maybe a little synthetic oil,wrong crosshatch angle ??? . I dunno why it took so long to break in. but it eventually did- I knew I had the ring end gaps right and piston to cylinder clearance was correct, so I ran it
- baldy110
- Thank you received: 512
- hannah1
Smoking is pretty common on a fresh engine. Break it in and it should stop. DO NOT baby the engine. Run it hard. If you baby it, it will smoke and the rings will not seat properly.
3rd gear , 10 pulls from 30% of redline to redline . That's what my engine builder always said , he built me several fast , long lasting roadrace engines .
- Johnny Red
- 80 KZ750 H LTD
OK so the engine has stop smoking after riding for about 20 miles. YAAAAAA!
As for the engine paint, I used a aluminum paint for engines.
It only took 3 1/2 weeks to rebuild! So you can do it too!
