To Locktite or to Anti-Seize, that is my question.
- Avenger
A bunch of years ago I followed instructions to use anti-sieze when bolting a sprocket to an aluminum hub.
The damn bolts backed out while I was riding (and yes I torqued them properly) and messed up the paint on my swingarm. Could have had a more drastic effect had I been hauling ass when the bolt hit.
Again, as it was told to me the anti sieze helps in that it prevents rust and gauling the threads on two different types of metals. In my little mind that tells me that I've lubricated a bolt so it doesn't rust and sieze up and that will not stop it from backing out.
Locktite, again as told to me, is like a plastic. It fills the gaps between the threads and when it cures makes it harder for bolts to back out.
I could be wrong in my application but all I know is that I've not had a bolt back out or a part fall off any of my bikes since I started this process (and before that I had a lot of things come loose) and I've not messed up any threads (I think at one point I was an expert on re-taping stripped threads).
I also read somewhere that most good grades of bolts come with some sort of coating of anti sieze.
- wiredgeorge
- ibsen22000
- Thank you received: 1
(They say Harly Davidsons don't use enough Locktight on their stuff. In fact the moto is if something falls off, don't turn around. There will be another one up the road!)
- Little B
- Thank you received: 3
Turns out that threadlocking compounds like loctite are 'anaerobic adhesives'. They are not like super glue at all. They work when two conditions are met: 1)No air (oxygen) & 2)In contact with metal.
When the above is satisfied, they act as a catalyst to 'set off' the stuff. It then becomes a plastic. My guess is that the reason it works with the anti-seize too is because somewhere within the threads as the bolt is tightened, the loctite comes in contact with a small area of un-coated metal. It doesn't have to be a large area at all. In fact, the tip of a nail will set off a whole tube of the stuff.
One manufacture says that the compounds actually lubricate the components as well. If that is the case, using anti-seize may be redundant.
1981 KZ750-H2 LTD
- Avenger
I don't understand the need to anti-seize compound in a "mock up"... a fastener can't seize that quickly.
To prevent galling.
- RollingStock
To prevent galling.
huh?.. just seems like a waste of money and time u guys are going threw.. iv work at a great bike shop we never used anti seize on anything... we only used locked tight when it was needed..
iv build about 7 bikes myself. and put down many of miles and took them apart more times than id like too, never had a problem with not using antiseize..
even on the drag bikes we build.. pulled them apart sooooooooooo much never had a problem with galling or anything alone those lines
73 z1900 street nitrous drag bike(powered but honda)
83 kz750 turbo street fighter project
- Avenger
What did you guys use on Axles?
- RollingStock
little bit of gease..
