- Thank you received: 3
650 firing on 3 cylinders
- hardr0ck68
- Who put the what in the where?
1) Cylinder #1 header pipe is only getting warm. The plug was wet. All the plugs are black which is odd because I am running pods and 4-1 with stock jets... Oh yeah and I need the choke on for the bike to run. I used carb cleaner to try and find an air leak but did not hear a change ( but it's hard to tell as the idle stumbles).
2) This belongs in electric, but I don't want to post two threads right now... My blinkers don't blink!! They come on and stay lit. Is there a way to test the blinker assembly? I switched the blinker assemblies (the bike has 2, is one for the hazards? they don't work either...) and that did not fix anything. I was trying this without the bike running, but has 12.25v at the battery and 10.5 at the lights...
Any help?
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- BSKZ650
- Thank you received: 14
these bikes take a while to warm up also
have you checked all the bulbs to see if they are good
77 ltd1000, current rider
76 kz900, just waiting
- Thank you received: 2829
I fixed my blinker problem by replacing the stock flasher unit with a Tridon Stant #552 (2 terminal)variable load unit. Bought it at a local auto parts store and now the blinkers always flash. Ed '77KZ650C1
- hardr0ck68
I will go out later and check to see if there is spark to #1, I think I will also pull the float bowl screw to be sure there is fuel making it to the #1 carb.
the lights are all good, I replaced the stock turn signals with cheapy smaller units. I will try the blinker unit you mentioned, hopefully it will cure my problem.
1977 kz650 c1
- hardr0ck68
any idea as to what could keep #1 from working?
Thanks
1977 kz650 c1
- N0NB
- Blue handles better
Alternately, are the carbs assembled correctly? I ask because I found a jet needle installed incorrectly, with both plastic spacers under the e-clip after I bought my SR which was causing that cylinder to flood out.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
- hardr0ck68
the plug wires are new they were installed with my dyna coils... I will check the connections but I am sure I did it right.
valve clearance should be good (i checked it when I put the head back on....)
1977 kz650 c1
- Thank you received: 2098
well, over a year later, i started the bike up today and #1 is not firing.
Thanks
If not already done, would swap #1/4 plug wires to determine whether misfire stays on #1 or moves to #4.
This could aid diagnosis.
Would also install 4 brand new spark plugs and visually inspect spark quality on each plug before installing it.
If spark is all good with new plugs and misfire continues, would consider possible compression issue, often resolved by valve adjustment.
Good Luck!
- N0NB
Nate
- hardr0ck68
1977 kz650 c1
- hardr0ck68
compression seems good to my thumb, on Monday i will get a gauge on Monday and see what it is for sure.
spark is strong when i pulled the plug cap it was sparking through the rubber 2 inches away to the case... i switched plus and plug wires with #4 and nothing changes.
carbs, i pulled them and checked everything, i found a blockage in #1 (the tube that runs next to the main jet..) i cleared it and put it all together, it ran poor so i adjusted the idle... I don't know if #1 started firing for a bit or not, the pipe seemed to get hot but when i pulled the plug wire it ran the same.
I think #1 ran for a minute or two but the carb may have re-plugged up or something. the odd thing is spraying starter fluid into the carb did not change the idle of the bike (spraying it into the other carbs would make the idle drop and stumble.... so i don't know
1977 kz650 c1
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
