Need help with stator rotor
  • djturnz
  • djturnz's Avatar Topic Author
Re: Need help with stator rotor
15 Feb 2006 10:23
#24055
When you guys are removing the triple bolt, what holds the front end on (up)? just curious.
1982 KZ750 (4) LTD
  • wireman
  • wireman's Avatar
15 Feb 2006 20:13
#24167
top pinch bolts on fork legs,pinch bolt on top tree,big nut under top tree,500 lbs of kawasaki,allright its just skill!bwaha:whistle:
  • MDawnz1
  • MDawnz1's Avatar
17 Feb 2006 14:52
#24539
Do you know any firemen ?
Or body repair men ?
See of you can dig up a portapower setup.
(hand held hydraulic press setup)
Face it, if you have been hitting on it and heating it,
your crank is SHOT !!!
Time to start looking for a new one (unless you are luckier then I ever have been) Or find someone to rebuild yours.
It sounds like the stator spun on the crank and welded itself to the crank. :(
1974 Z1a, still 903
  • djturnz
28 Feb 2006 05:44
#27027
What is the correct thread size for the puller?
Is it 18mm X 1.5? 16mm 20mm? I want to get the correct tool before I try again.
For the bearing is steel ok?
1982 KZ750 (4) LTD
  • wireman
  • wireman's Avatar
28 Feb 2006 07:27
#27052
steel is fine for the bearing,use the big bolt in the center of top triple tree.;) goodluck,happy wrenching!
  • djturnz
07 Mar 2006 10:18
#29018
OK, I ordered the bearing. It came to me at work today. As I suspected, it looks awful small, unless I don't understand something. 3/8 seems kind of small.
I am assuming that I insert the bearing so that it is seated in the top of the hole that the bolt that holds the rotor on threads into. And this is to give me something for the 18mm bolt to push off of.
Is this correct? Is it really 3/8 inch?
1982 KZ750 (4) LTD
  • wireman
  • wireman's Avatar
07 Mar 2006 11:23
#29040
get a bearing thats just a little smaller than threads on triple tree bolt.ill look around and find one of mine and send it to you pm your address to me and i will mail it to you tomorrow;)
  • djturnz
09 Mar 2006 07:36
#29578
were you able to find a bearing? If not it's cool. I might just end up cutting.
1982 KZ750 (4) LTD
  • wireman
  • wireman's Avatar
09 Mar 2006 08:24
#29591
im gonna try and get over there today ,its out in ashland i think .it wil be in mail by weekend:whistle:
