650/750 head gasket
  • mariozappa
  • mariozappa's Avatar Topic Author
650/750 head gasket
06 Nov 2007 05:40
#179811
Using the new and improved Kawasaki Parts Diagrams, I came across identical part #'s for a 650 head gasket and a 750 head gasket.
part #11004-1107.
which was replaced by a newer part # 11004-1268
I was unaware this gasket would be the same on a slightly larger displacement engine.
Is this correct or could there be an error on the website?
The part # was listed the same for many (but not all) 650's and 750's.
Post edited by: mariozappa, at: 2007/11/06 09:16
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • mariozappa
Re: 650/750 head gasket
08 Nov 2007 10:26
#180132
No answer eh? Oh well, I have the 650 apart and will have the 750 apart this weekend. I let you know the anwer then...
1977 KZ650C1
  • Bluemeanie
  • Bluemeanie's Avatar
08 Nov 2007 16:42
#180190
I guess it's possible. On the 650 it would be just a tiny bit bigger with no ill effects on the engine?
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
08 Nov 2007 17:01
#180195
Let us know. Will be good info.
eh?
You a former Canadian Mario?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Bdog
  • Bdog's Avatar
  • Sweep the leg johnny!!!
10 Nov 2007 04:50
#180433
When I got my cometic it was universal for 650 and 750. the diameter difference is like 1mm the whole way around, cometi=c said there is no problem, they know there stuff.
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
10 Nov 2007 05:49
#180441
I don't know if this helps, but the original part # for the '77 KZ650 head gasket was 1104-073 then replaced by #11004-1005. These are from my old parts catalogs. If anyone has an old KZ750 catalog it would be interesting to see the original #'s for it. Ed
  • mariozappa
12 Nov 2007 05:05
#180641
Bdog is right.
In my best Canadian accent
There is aboot 1mm (if that) difference all the way around the inside cylinder of the gasket.
The 750 gasket sits aboot 1mm out from the edge of the sleeve while the 650 gasket comes right up to the edge of the sleeve.
1977 KZ650C1
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
12 Nov 2007 05:48
#180642
:laugh: :lol: B)
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
