81 KZ 750 LTD - What is a coil?
  • dankest
  • dankest's Avatar Topic Author
17 Oct 2007 12:11
#176719
I have a 1981 KZ 750 LTD, 4 cylinder.
Cylinders 1 and 3 are not firing. I can tell by the pipes not getting hot on that side. The wires have power going through them. I was told by someone to check the coil, underneath the gas tank? I don't know much about these bikes so I'm trying to figure out what that is and if anyone knows of any other problem I could be having?
Also I have a problem with my idle sticking in high RPM's. Could that be because of it only running on 2 cylinders? Or do the carbs need cleaned?
Thanks alot!
  • dankest
Re: 81 KZ 750 LTD - What is a coil?
17 Oct 2007 12:15
#176721
Could it be the ignition coil? Maybe thats what the person was meaning.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
17 Oct 2007 12:26 - 03 Dec 2008 07:29
#176724
del
Last edit: 03 Dec 2008 07:29 by JMKZHI.
  • Skyman
  • Skyman's Avatar
17 Oct 2007 12:31
#176726
The coil is going to be a black (probably) plastic-looking cylinder underneath your gas tank. The spark plug wires come out of it. The left coil fires cyls 1 & 4. The right fires cyls 2&3.
You wrote that the "wires have power coming out of them". Does this mean that you have confirmed that you ARE getting spark? What is the condition of your plugs?
A quick way to test for spark is to remove the plug from the engine, connect it to the spark plug wire, and lay the "spark end" of the plug against the engine so that it is grounded. Take the other spark plug wires off the plugs so the engine doesn't try to start, then crank the starter. You should see a good blue spark at the tip of the plug.
West Linn, OR
  • dankest
17 Oct 2007 12:46
#176727
I meant cylinders 2 and 3 aren't firing. The pipes on the right side(when sitting on it) don't get hot. I have a spark in all wires and plugs.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
17 Oct 2007 12:57 - 03 Dec 2008 07:30
#176728
del
Last edit: 03 Dec 2008 07:30 by JMKZHI.
  • dankest
17 Oct 2007 13:01
#176729
Yea, 3 and 4.
Like I said, I don't know much about these things. The bike is 4 years older than me.
I plan on doing a lot of stuff to it, and learning on the way.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
17 Oct 2007 13:13 - 03 Dec 2008 07:31
#176732
del
Last edit: 03 Dec 2008 07:31 by JMKZHI.
  • dankest
17 Oct 2007 13:39
#176736
Correct, they are connected as you said.
  • pshaw
  • pshaw's Avatar
17 Oct 2007 16:06
#176756
Sence you said you have power I would check to make sure you are getting gas to those 2 carbs. If it like mine 1 line feeds 2 carbs and the other feeds the other 2 carbs. good luck.Pat
1976 kz ltd 900
  • JMKZHI
  • JMKZHI's Avatar
Re: .
17 Oct 2007 20:00 - 03 Dec 2008 07:31
#176801
del
  • JMKZHI
  • JMKZHI's Avatar
Re: .
17 Oct 2007 20:09 - 03 Dec 2008 07:32
#176803
del
Last edit: 03 Dec 2008 07:32 by JMKZHI.
