WOT when testing compression?
- Skypilot54
16 Oct 2007 10:31 #176444
by Skypilot54
WOT when testing compression? was created by Skypilot54
OK, so I'm the kind of person who's not satisfied with just the "what", I need to know the "why". I'm trying to get my mind around why compression is tested while holding the throttle full open. The engine's not running (just cranking), so what's the reason behind holding the throttle open when checking compression?
- Bluemeanie
- Thank you received: 14
16 Oct 2007 10:54 #176448
by Bluemeanie
Replied by Bluemeanie on topic WOT when testing compression?
I believe it has to do with the engine being able to spin over freely without any restrictions, such as compression (all plugs out) and air flow (closed throttle blade)?
Post edited by: Bluemeanie, at: 2007/10/16 13:55
- Rickman
16 Oct 2007 10:56 #176449
by Rickman
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
Replied by Rickman on topic WOT when testing compression?
So as not to restrict the airflow in any way. It removes another variable from the environment. Instead of holding the throttle open, you can just pull the carbs off (So easy, right?)
- steell
16 Oct 2007 11:09 #176457
by steell
Replied by steell on topic WOT when testing compression?
How much air are you going to get into the cylinders if the air supply is blocked off? You are not going to have much compression if there is no air to compress
It's like trying to breathe with your nose pinched shut and your mouth closed, it just don't work real well
- Skypilot54
16 Oct 2007 11:13 #176459
by Skypilot54
Replied by Skypilot54 on topic WOT when testing compression?
OK, that makes sense. Even though the plugs are out, intake air has to be there to "compress" so the gauge has something to read. If I understand correctly then having it wide open will take as much restriction as possible out of the incoming side so that you get a truer reading on the compression side. So, if you check compression with a closed throttle, you're compression would be incorrect by showing too low of a number?
- Bluemeanie
16 Oct 2007 12:26 #176483
by Bluemeanie
I'm sure it would make a differance, next time you do a test try it. I would think the numbers would be a little lower!
- steell
16 Oct 2007 13:46 #176495
by steell
Depending on variables, the compression will generally be 30-70 psi lower when testing with the throttles closed.
