Spark Plug Thread question
- GregZ
13 Sep 2007 18:27
When installing plugs on my 75 z three of the four plug holes are very smooth. #2 plug hole is very tight. It doesn't appear to be stripped but the plug goes in with resitance and seems to get harder to tighten towards the head. Any old tricks to fix this problem with the head on the bike. I just installed a new header and smooth bores so the plugs been in and out a few times.
thanks
gregz
thanks
gregz
- jjdwoodman
- Live free, or die.
Re: Spark Plug Thread question
13 Sep 2007 18:36
Probably ought to chase the threads with a die before you gald them... just clean out the cylinder good afterwards, and oil the threads of your plugs anytime you install them.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
81 550 Mostly there
83 ZN1300 Voyager
- GregZ
13 Sep 2007 18:42
Ok. What size tap would I need for a spark plug hole ?
Post edited by: GregZ, at: 2007/09/13 21:49
- themachine
13 Sep 2007 18:55
use anti seize lubricant, as oil has a tendancey to carbon up and cause your plugs to sieze up in the head.
unless you take them out every 100 miles like i do.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- JR
14 Sep 2007 16:19
GregZ wrote:
Had same problem a long time ago and used an old plug to make a tap. Used a hacksaw blade and cut four slots in the threads and at right angles to the thread. You could probably do this pretty fast if you have a Dremel type tool and a cutting wheel.
Screw in about a turn at a time and remove and check for any metal shavings. repeat etc.
Ok. What size tap would I need for a spark plug hole ?<br><br>Post edited by: GregZ, at: 2007/09/13 21:49
- jjdwoodman
14 Sep 2007 16:33
The hacksaw trick can work in a pinch, but I trust a regular tap more as the have more room to get rid of your shavings, which is really important on aluminum.
Any auto supply can set you up with the right tap... just bring in your spark plug for a measurement. They are much cheaper than heads:P
77 650b
81 550 Mostly there
83 ZN1300 Voyager
81 550 Mostly there
83 ZN1300 Voyager
- kawsakiman
14 Sep 2007 17:19
standard 14 mm plug tap/thread chaser
