Cam Cover Rubber End Caps
- 1045
21 Aug 2007 18:07
Hello all,
I was just replacing the (4) rubber cam cover end caps on my 77 1000 with new ones from Z1 enterprizes....I am having alittle trouble keeping them in place as the top pan is torqued down, they seem to want to squeeze outwards....I tried to put RTV on them and also tried to put them in without anything on them with the same results..... Anybody have this trouble before???? Its almost like they are a little bit too high and get squeezed just a bit to much.....
Thanks
1045
Thanks
1045
1045
- 76 LTD
Re: Cam Cover Rubber End Caps
21 Aug 2007 18:50
try some yamabond or better yet throw them in the trash and get some aluminum caps from APE just a dab of silicone and they are good to go and will not blow out like the stockers.
- cgray34
21 Aug 2007 19:37
I too am dealing with your frustration. I just replaced the caps on my 80 kz1000 and the same thing is happening. I couldnt get one of them to stay in. I put it in backwards with the lip on the inside. I heard about this little trick from and old kz rider. Maybe not the best solution, but it works. By the way, that was over the weekend, and today tuesday I had another try to slip out and I did the same with it as well.
I like the idea of buying aluminum ones! Good Call!
- RonKZ650
21 Aug 2007 20:43
I guess I don't understand the problem, as the way they are made they have a kind of lip that holds them from moving outward from the head. They will squash down some, as this is how they are supposed to seal. Use Yamabond #4 or equiv, don't use silicon. They should seat nice and neat every time. They always did for me, but it's been 20+ years since I replaced a 1000 plug. Did a 650 a week ago though the same way and it worked just the same way. Use Yamabond #4.
- cgray34
22 Aug 2007 07:08
APE fully machined billet aluminum cam cover plugs for the Kawasaki. Won't blow out or suck in as the stock rubber plugs do on this model. Fits all Z1, KZ900, and 1000s except J Model. Bright blue anodize finish.
99278 Set of 4 $33.00
www.firedogracing.com/APEKZ.html
Ron, the rubber plugs have a lip on one side only. Obviously, you know how they set in the half moon slot. When the valve cover is tightened they love to come out. Alot of times they slip out because the valve cover is warped(sorry for the bad news). Anyway, putting the lip on the inside looks hideous but works. Functionality or form?
Above I put the link for the aluminum caps.
Later,
cgray34
Later,
cgray34
22 Aug 2007 11:08
Not owning a KZ900/1000 I had never noticed the difference before, but this problem doesn't happen of the KZ650 because a cam cover bolt runs through the center of each plug. Ed
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
22 Aug 2007 11:21
I used ThreeBond 1104, and had no problems, no leaks.
West Linn, OR
- 1045
22 Aug 2007 20:02
Thanks for the responses, I will try and bond them in place and let it dry before tightening down top pan, shouln't complain as it only took 30 years for the old ones to start leaking..........
1045
1045
1045
- auggiedog
28 Aug 2007 08:18
All,
don't forget that the APE plugs need to be fitted, i.e the tops may have to be decked a little to get them as flat to the top of the head as possible...otherwise you might leak...
K
K
- auggiedog
28 Aug 2007 11:34
All,
K
K
- auggiedog
28 Aug 2007 11:34
All,
K
K
- APE Jay
29 Aug 2007 00:25
I have never heard that before. Been making those for 20 years. We hold that dimention to +/- .001" Should not ever need to be cut to have leak free fit.
Jay
Jay
