another racing engine
- riverroad
- 1980 1000LTD B4
15 Aug 2007 15:59
I just repaired two spark plug holes via Time-serts, and installed four new spark plugs gapped at .040". I touched nothing else. Now the engine won't idle below 3200 rpms. I checked all of my vacuum lines and caps etc. and can't find any vacuum leaks. The idle screw is all the way out and it is up against the stop. I also checked my throttle cable and it isn't pinched or kinked or anything.
Could the fact that its been over 100 degrees outside have anything to do with it? Today registers right at 105. I also took it for a little spin down the street and goosed it once and it did seem really weak.
Can SOMEBODY HELP ME??
Maybe its because my mother in law is coming tomorrow and its just trying to skip town. I dunno.:pinch:
Post edited by: riverroad, at: 2007/08/15 19:01
- KZQ
- Administrator
Re: another racing engine
15 Aug 2007 17:15
It's not the heat.
Sure does sound like a vacuum leak. Make sure that not only are the vacuum hoses connected but also that you haven't inadvertently cracked one. Look for cracks that not only cross the hose but also for cracks along the length of the hose.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- riverroad
- 1980 1000LTD B4
15 Aug 2007 17:50
Thanks KZCSI, good tips. I hadn't thought about lengthwise cracks. Other than that, I've looked at all the rubber, and it does look good, still pliable, no visible cracks, although I do realize it's all original, and really needs to be replaced. My next plan of attack is to start it back up and start squirtin WD-40 at the carb bases etc., right after this beer...or two...:whistle:
- larrycavan
16 Aug 2007 12:36
You didn't recently synch the carbs by any chance??
- BSKZ650
16 Aug 2007 13:49
I wonder if the plug wires are giving you a problem, have you shot some water on the pipes while it is running to see if you have a dead cyl, my thought is since the plugs have been in there a while and you pulled the wires you may have one or more that has a bad end on it
77 ltd1000, current rider
76 kz900, just waiting
- nads.com
16 Aug 2007 16:34
Did you nick a valve when you drilled the holes? Seen that happen before.
- riverroad
- 1980 1000LTD B4
17 Aug 2007 05:14
Well, I didn't get a chance to mess with it last night. But I do know it was firing on all four. And yes, I made damn sure the valves were closed before I tapped the holes. It could use some new wires though, but they were all firing. I just couldn't get the idle down. It has to be a vacuum leak. I just haven't found it yet. I did pick up some vacuum port caps and some vacuum hose from a parts store yesterday. Maybe I can jump back on it tonight. But I also have to go fix my dads lawnmower tonight too, plus entertain my mother in law later.
Maybe someone can explain this thing's vacuum system to me? There's two vacuum lines running from #1 and #4 carb bases which are connected to a tee, which then runs to some doodad up by the coils. That doodad has two large tubes running down to the top of the valve cover. One of those larger hoses is cracked. Do I really need that doodad? Can I just bypass the doodad and plug the vacuum ports?
- mariozappa
17 Aug 2007 06:05
I believe the stuff you are talking about is the emissions equipment. THROW THAT STUFF AWAY! Plug the holes on the valve cover or just run a tube from one to the other. If you have the stock airbox, you'll probably have a hole to plug there too.
I'm not familiar with the lines running from the carbs.
You would probably have to cap off the openings where you remove those hoses too.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- riverroad
- 1980 1000LTD B4
17 Aug 2007 06:36
Thanks Mario, that's what I thought. I'll probably just run a hose from one side to the other for now, and plug the carb base ports. Maybe I can come up with some trick looking aluminum block off plates or something later.
- mariozappa
- kz1000dragster
17 Aug 2007 14:03
The spark plug gap sounds too high try .032 or .035
