WILL IT BOLT IN?
- Grease Monkey
WILL IT BOLT IN?
07 Aug 2007 23:09
I have an 82 KZ1000 CSR and have come across an 80 LTD on the cheap. Frame is in much better condition than mine. Will my J motor bolt in to the LTD frame?
Thanks
Thanks
- StreetfighterKz
Re: WILL IT BOLT IN?
08 Aug 2007 04:16
If its an "old" style LTD with a Z1/Kz motor then no. I think '81 and up is the J style motor.
You can make it fit, but it's not a bolt in. A couple of the motor mounts moved around between the two.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Nephlyte
- To do what is right is to know what you want.
08 Aug 2007 13:13
StreetfighterKz wrote:
yup.
Later, Doug
yup.
1979 KZ1000 MKII, 1075 wiseco kit installed, 10.25:1 compression, welded crank, kerker header and custom paint.
08 Aug 2007 13:25
ck out mrmagoo's project in the projects archive.he's doing a z1r the other way and shows what mounts he had to move around might be helpful.
