Cam cover end cap interchangability.
- tjettim
02 Aug 2007 10:47
On the rubber end caps on the head,yhat the
cam cover seals against,are any models,1000,
650,750,interchangable? If so how about a KZ1000
to a 1984 Honda 650 nighthawk? Honda wants 18
bucks a piece for them,and nobody else lists any.
- PLUMMEN
Re: Cam cover end cap interchangability.
02 Aug 2007 12:00
i dont know about interchangability but can you clean up the ones you have and glue them back in with a little clear silicone?
ive also seen a honda section on z1 enterprises site,not sure how much he has but it might be an option for ya
- RonKZ650
02 Aug 2007 12:04
All KZ550, 650, 750 fours use the same plug. Z1, KZ900, KZ1000 up through 1980 use a larger plug. KZ1000 and 1100 from 1981 up use a different plug yet. As if Honda will fit any of them I would highly doubt. These plugs should be everywhere for $5-$10 each.
I'll mention again gluing on old hardened worn out rubber is not a long term fix, trust me. Just replace them.
Post edited by: RonKZ650, at: 2007/08/02 15:06
02 Aug 2007 12:45
www.partsnmore.com/cat_index.php?model=k...1000&category=engine
here is a link they have them here for$3.00 ea.
02 Aug 2007 17:21
I believe you can get them at Z1 Enterprises. See:
www.z1enterprises.com/SearchResult.aspx?...e&KeyWords=92066-017
- tjettim
02 Aug 2007 19:00
Neither of the above webites list gaskets for a 83-85
650 Nighthawk.I will need to take them out and compare
them to a KZ1000 plug I guess.I was hoping someone out there had aready made the swap.
- darmahsd
03 Aug 2007 14:52
Get these aluminum Klasmo ends and never have a problem again. Plus at $40 a set, are cheaper than OEM. They look cool in anodized silver, blue or red. Contrary to what everyone says about RTV, you do need the silicone to seal these, but just a small bead as not to squeeze out into the cam galleys to start plugging up stuff in your engine. <
www.z-klasmo.de/
< www.americanclassix.com/kawa_improvements.html >
< www.americanclassix.com/parts/new11/IMG_6783.jpg >
Stephen
Stephen
