Changing the oil. How much?
- Ray J
01 Aug 2007 17:46
I was frustrated. Now I'm scared. How much old oil is supposed to drain when you change your oil? I just drained my oil and only 2 quarts and 24 ounces came out. The manual says 3.9 quarts. According to my math, this ain't even close. Is there a lost quart up there somewhere? The oil level was right at the middle of the window when I started.
- The Milkman
Re: Changing the oil. How much?
01 Aug 2007 17:59
Did you pull the filter, some more will come out with that too?
- Ray J
- donthekawguy
01 Aug 2007 18:27
3.9 quarts if no oil cooler.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- donthekawguy
01 Aug 2007 18:29
Woops should have read the post. 1 quart don't seem too bad. Did you have the bike on the center stand when you checked it before you drained it?
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Ray J
01 Aug 2007 18:53
I don't have a center stand. I was just balancing the bike by hand and the oil level was right in the middle of the window.
Post edited by: Ray J, at: 2007/08/02 08:04
- austin3119
02 Aug 2007 21:35
Don't worry about it. These old engines are pretty darn near bullet proof. You could probably run 1.5 to 2 quarts and be just fine, although obviously I wouldn't reccomend it.
No worries.
No worries.
- Ray J
02 Aug 2007 23:58
OK, I'll just put in enough to get it even with the fill line in the window. Not sure that I won't worry, though. Seems like there should be a reason for missing a quart. Maybe it's a government bike where specs are only rough guidelines.
- JR
03 Aug 2007 06:59
Ray J wrote:
That's all I've ever done with any bike I ever had. As long as you fill up to the mark and keep it up to the mark or wherever it should be you will be fine.
OK, I'll just put in enough to get it even with the fill line in the window........
- ltdrider
03 Aug 2007 07:24
Don't sweat it, Ray.
I don't know where all the oil goes, but it's nearly impossible to get it all out.
As long as you can see it in the sight window when the bike is level, you're good.
When you fill it, bring the level up the the middle of the sight glass (with the bike level). Then run it a few minutes. Let the oil settle, and add oil if necessary to bring it back to the middle of the sight glass.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
03 Aug 2007 10:40
The original '73 Z1 Owner's Manual says oil level should be between the lines on the inspection window, and stresses not overfilling. Also says where engine has just been run, to wait several minutes until the oil settles before taking a measurement.
- Ray J
03 Aug 2007 12:22
Thanks guys for the info.
And say a prayer for those lost in the brige collapse.
35W is the northern lifeline to Minneapolis. There is no other freeway going north out of the city. Traffic is going to be nuts for the next year and a half.
