Engine just STOPPED????
- Wizzard
01 Aug 2007 13:41
Well heres the storie. I was on my way to work stopped for some smokes then restarted the bike ( witch was not making any strange noises what so ever and running good)I leave the store and go about a 1/2 mile to a red light put the bike in neutral bike still soundin good light goes green I grab the clutch as soon as I hit the shifter to put it in first the bike stoppes. The engine will not move got it to move a hair when I got the bike in gear and rolled it backwards. took the valve cover off and every thing looks good under there. Piston 1 is at the bottom with the exaust valve open 2 is at the top no valves open 3 at the top with the intake valve open and 4 at the bottom no valves open. This is all I know. Any Ideas where to star??
:blink: :S
Post edited by: Wizzard, at: 2007/08/01 16:42
1977 KZ 1000
4-1 Headder
K&N filter
530 Chain & Sprokets
Rear Air Shocks
4-1 Headder
K&N filter
Rear Air Shocks
- BSKZ650
Re: Engine just STOPPED????
01 Aug 2007 13:49
are you sure it may not be the front sprocket, may have come off and got stuck
77 ltd1000, current rider
76 kz900, just waiting
- Wizzard
01 Aug 2007 14:08
No Im not sure but I'm going to go right now and check cause my chain is really lose!!! Lets hope!!
1977 KZ 1000
4-1 Headder
K&N filter
Rear Air Shocks
4-1 Headder
K&N filter
Rear Air Shocks
- Wizzard
01 Aug 2007 14:14
Nope that wasn't it sprocket still bolted(not) still on.
Post edited by: Wizzard, at: 2007/08/01 17:28
1977 KZ 1000
4-1 Headder
K&N filter
Rear Air Shocks
4-1 Headder
K&N filter
Rear Air Shocks
- The Milkman
01 Aug 2007 17:01
Not sure how your cam marks are supposed to line up but have you checked that with you manual???
Ride safe.
Ride safe.
- BSKZ650
01 Aug 2007 18:02
well you just aint no funB)
did you pull the plugs, and if so what did they look like, , next what does the timing chain look like
- coppertales
02 Aug 2007 08:39
Has the engine seized up? Can you turn it over? Mine quit dead a few months back from a blown main fuse. Not enough info to go on. You did not accidently hit the kill switch did you.....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
02 Aug 2007 12:13
Question, please --- At this time, does squeezing and releasing the clutch lever feel "normal" as with the usual disengagement and engagement of a properly operating clutch?
- Wizzard
02 Aug 2007 13:46
1 Well the plugs look fairly normal a little rich but not bad.
2 The clutch feels a little tighter or harder than normal.
3 I can not move the engine at all tight as a nuns $%^&
4 the timming chain looks ok did see anything abnormal.
1977 KZ 1000
4-1 Headder
K&N filter
Rear Air Shocks
4-1 Headder
K&N filter
Rear Air Shocks
- Fossil
- Wizzard
02 Aug 2007 13:58
A little low but not too bad.
1977 KZ 1000
4-1 Headder
K&N filter
Rear Air Shocks
4-1 Headder
K&N filter
Rear Air Shocks
02 Aug 2007 15:22
Wizzard wrote:
Here just for reference only is what the FSM Trouble Shooting Guide says under "Engine won't turn over"
Valve seizure
Valve lifter seizure
Cylinder, piston seizure
Crankshaft seizure
Connecting rod small end seizure
Connecting rod big end seizure
Transmission gear or bearing seizure
Canshaft seizure
Kick ratchet gear not engaging
Primary reduction gear broken
But in your case, none of these seems immediately suspicious (to me at least) because of the sudden problem onset with a good running engine at low rpm, oil level okay, no smoke, no unusual noise.
Anything noticeable through the spark plug holes (such as a valve possibily in contact with a piston)?
Is there any movement of crankshaft in either direction by turning the 17mm nut on the end of the crankshaft (under the ignition cover)?
Fingers crossed in hoping for you an easy simple solution.
...not making any strange noises what so ever and running good)...go about a 1/2 mile to a red light put the bike in neutral bike still soundin good light goes green I grab the clutch as soon as I hit the shifter to put it in first the bike stoppes. The engine will not move got it to move a hair when I got the bike in gear and rolled it backwards. took the valve cover off and every thing looks good under there. Piston 1 is at the bottom with the exaust valve open 2 is at the top no valves open 3 at the top with the intake valve open and 4 at the bottom no valves open....
Valve seizure
Crankshaft seizure
Canshaft seizure
