Engine just STOPPED????
  • Wizzard
  • Wizzard's Avatar Topic Author
Re: Engine just STOPPED????
02 Aug 2007 15:35
#161404
Haven't tryed to move it that way yet (its way to hot in my LITTLE shed with a TIN non insulated roof) valves that I can see 1 exaust valve and 3s intake valve look ok as far as I can tell. A bike shop owner buddy of mine said to check the clutch and see if anything s wrong in there. I'm hopping it cooler tomorrow night after dark so I can get in the shed with out passing out and checking all the ideas everyone is helping me with. Thanks for the help and keep it coming.;)
1977 KZ 1000
4-1 Headder
K&N filter
530 Chain & Sprokets
Rear Air Shocks
  • BSKZ650
  • BSKZ650's Avatar
02 Aug 2007 16:11
#161415
drain the oil and pull the filter, see if there is a bunch of metal in the pan or the filter, smell the oil to see if it has a burn smell to it.
77 ltd1000, current rider
76 kz900, just waiting
  • Wizzard
08 Apr 2008 12:16
#205050
Well I found out the problem someone had a tensioner come apart and did not bother to go after the rubber part with the metal on it and my timming gear on the crank picked it up and it stuck to the gear and through my timming out and bent all 4 intake valves. so I now have it fixed and all back together and now it wont run the best I have hed is 2 cylinders I have re timed the hole engine many times, have spark at all 4 plugs and gas but won't run? Totaly lost:dry: :blink: :unsure: :(
1977 KZ 1000
4-1 Headder
K&N filter
Rear Air Shocks
