gpz1100 head
- KzJim
gpz1100 head
04 Jan 2006 15:30
Will an '82 gpz1100 head fit on the 76 bottom end?.. I know the 84 will...
Naiveté in grownups is often charming, but when coupled with vanity, it is indistinguishable from stupidity.
Tis better to remain silent and thought a fool - than to speak up and remove all doubt.
Did ever think that maybe you've been doing it wrong all these years?
- bob_z1
Re: gpz1100 head
04 Jan 2006 15:47
yes it will fit,
it will need the same modifactions the 84 head needs to work on the 76 bottom end.
- KzJim
Re: gpz1100 head
05 Jan 2006 04:06
Thanks bob.... thats what i needed.. dosent the 82 head have the injector port in the head rather than in the throttle body like the 84 unit?
- Russ
Re: gpz1100 head
05 Jan 2006 04:27
I'm pretty sure only the 81 GPZ had the injectors in the ports but I haven't got my workshop manual handy to check.
- KzJim
Re: gpz1100 head
05 Jan 2006 06:12
Bob,
I know the cam gears/chain are diffrent between the kz and the gpz as well as the cam chain tensioner. I can get those parts from APE. What else needs modifing?
- APE Jay
Re: gpz1100 head
05 Jan 2006 10:36Please Log in or Create an account to join the conversation.
- KzJim
Re: gpz1100 head
05 Jan 2006 13:20
Thanks Jay... i take it you work at ape? if so i have a question for you regarging the porting of the 1100 head. what is the final MM size of the intake port after ape is finished with it. and where can i get larger intake boots?
- Duck
- e vica na i sau na ga
- bob_z1
Re: gpz1100 head
05 Jan 2006 16:09
only the 81 GPz1100 had the ports in the head. don't forget going to that head will drop your compression about 2 points I think it is.
- KzJim
Re: gpz1100 head
05 Jan 2006 17:36
Duck... no i have a line on a head... and am just making sure it will work...
- steell
Re: gpz1100 head
05 Jan 2006 17:39
bob_z1 wrote:
I thought that only applied to the redesigned head used on the 83 and up GPz1100's?only the 81 GPz1100 had the ports in the head. don't forget going to that head will drop your compression about 2 points I think it is.
- APE Jay
Re: gpz1100 head
05 Jan 2006 18:06
No, the J model and early GPZs will also drop the compression with KZ style pistons.
Jay
Jay
