jumped timing chain
- jjdwoodman
- Live free, or die.
Re: jumped timing chain
25 Jul 2007 07:46
NO. should open the advance plates unless you just keep going or they re stuck;) I've been able to open mine with a screwdriver CAREFULLY, with everything still togeter just reach in behind the points plate. Unless they're stuck of course, then you have to take it loose to free em up
Post edited by: jjdwoodman, at: 2007/07/25 10:50
77 650b
81 550 Mostly there
83 ZN1300 Voyager
81 550 Mostly there
83 ZN1300 Voyager
- BINJIEU
- Always leave 'em smiling!
25 Jul 2007 10:07
OK, I think I've got the idea. Thanks for all the insight. I'll be toying with it tonight and get back to you all tomorrow. Sure hope to figure it out soon. I'd like to ride before the white stuff flys, and I also want to get to work on my BMW r65 too, but one thing at a time.
77 KZ650 w/ Dyna S ignition and stock coils
81 BMW r65
91 BMW k100rs 4v
Lakeland, FL.
81 BMW r65
91 BMW k100rs 4v
Lakeland, FL.
- BINJIEU
25 Jul 2007 10:12
Hey SNAKEBYTE, how much for the coils in case I need them?
81 BMW r65
91 BMW k100rs 4v
Lakeland, FL.
81 BMW r65
91 BMW k100rs 4v
Lakeland, FL.
25 Jul 2007 10:37
Patton wrote:
Hello? Hello? tap-tap-tap Is this thing on? :huh:
...Strobe type timing light is best to actually see operation of advancer unit.
25 Jul 2007 10:39
- BINJIEU
25 Jul 2007 12:35
Should be able to see the advancement as I accelerate the engine with the stobe on the plate?
81 BMW r65
91 BMW k100rs 4v
Lakeland, FL.
81 BMW r65
91 BMW k100rs 4v
Lakeland, FL.
25 Jul 2007 16:12
BINJIEU wrote:
Yessir, easy as pie.
Advancer unit should be clean and lubed and freely moving back and forth (against the spring tension).
IMO, strobe timing light is also best method to check/set ignition timing (dynamic method -- with engine running) instead of static method using an ohm meter or light bulb with engine off).
Regardless, should clean and gap points before setting ignition timing.
First priority -- give crankcase oil the "smell" test to help assure it is not being diluted with gasoline.
25 Jul 2007 16:14
And far easier than avoiding duplicate posts. :lol:
Post edited by: Patton, at: 2007/07/31 09:53
Post edited by: Patton, at: 2007/08/02 15:19
- BINJIEU
30 Jul 2007 10:18
Well guys and goyls, here's my most recent disaster.
Took the bike back to the pro who got her running great and he found one of the condenser wires had apparently been rubbed raw and grounded out. A little tape and voila, great running machine once again. . . for about six miles. The damn thing just begins popping and backfiring. Spoke with the guy earlier and he's gonna look at it again. I discussed the carburation, possible advance issues, and even the tank cap possibly being a problem for fuel delivery.He agrees with everything discussed on the forum, but insists there is an ignition issue that needs to be resolved first before adressing the fuel delivery possibilities. I've offered more money, but he insists he'll get it running right.
Suggestions?
Suggestions?
81 BMW r65
91 BMW k100rs 4v
Lakeland, FL.
81 BMW r65
91 BMW k100rs 4v
Lakeland, FL.
- Snakebyte
31 Jul 2007 05:04
Tell you what I own a garage in Cleveland. If you can get it to me I be glad to work on it for $50. If it takes one hour or 2 weeks I'll see what I can find.
I dont see how a wire on the condenser being rubbed through will make it do what it is doing since the condenser is grounded any way. I think you need a different mechanic sounds like he doesnt check his work.:pinch: Thats costing you riding time.
One thing that didnt cross my mind was to check the charging system when it is running bad. Its possible that the stator gives out after getting hot causing lower voltage and we all know what that can do to coils and running.
- BINJIEU
31 Jul 2007 07:37
Was out in Cleveland a couple months ago. Had I owned the bike then, and knew of the issues, I certainly would've tossed it in back of the old pick-up and dragged it out to see you. However, things are as they are. Am still waiting on the results of this visit.
TO BE CONTINUED. . .
81 BMW r65
91 BMW k100rs 4v
Lakeland, FL.
81 BMW r65
91 BMW k100rs 4v
Lakeland, FL.
- flht1997
31 Jul 2007 10:41
Condensers are not grounded, if they were the bike would never run, cause you would not have spark. The condenser is a storage place for extra electricity when the points open to stop arching at the points. If the wire wore through it would ground out on the coil side never collapsing the field and no spark. I would highly recommend an electronic ignition either dyna or stock Kawasaki, and a coil relay.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
