Idler gears ruined
- Nephlyte
- To do what is right is to know what you want.
What i found was that one of my cam gears and the tower was completely ruined. The cam gear is in two pieces, the rubber completely torn away. Same with the tower, but it is locked in its metal housing. There is some gouging(nothing really harmful, just ugly) around the gear and in the metal housing.
How was my bike even running? And why would these gears be so ruined, they were in good condition when i finished this rebuild 6 months or so ago.
1979 KZ1000 MKII, 1075 wiseco kit installed, 10.25:1 compression, welded crank, kerker header and custom paint.
- wiredgeorge
- tjoe81
- Nephlyte
Also, has anyone had any problems with those liska billet steel ones? Thats what i am replacing it with.
- RonKZ650
- Thank you received: 240
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- Nephlyte
I was just concerned i had some odd problem.
- twinkyrider
78 kz1000A
Fond du Lac,WI
- RonKZ650
What kind of noise does the engine make when these start to go bad? I just picked up a '78 kz1000a recently, while it was quiet when I got it, it's come up with a sound that I suspect is cam chain related, clunky, pingy and somewhat rough running if you get on it even a little until you hit 3000 rpm or so, then it goes great. The bike now has about 13K, but was only driven about 350 miles in the last 4-5 years by the former owner. I've already put on close to 750 miles in the last 2 weeks.
I doubt these bad in a 13,000 mile engine. Like I said, the rubber goes bad from heat and age. You have the age, but not the heat in 13,000 miles. Mine went bad at about 130k in the 650 and my buddy I was just talking to yesterday reported his bad in his 70,000 mile 74 Z1 recently. Like anything in the world though, your mileage will vary. On my KZ650 when they went bad all it did was make for a noisy camchain you could hear real easily as being something wrong, but not any horrific grinding noise or any difference at all in how the bike ran. Have you done the manual camchain adjust that takes 5 minutes to do? This may be all you need if it is a camchain noise.
- Gman
- Thank you received: 5
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
- Snakebyte
- Thank you received: 1
- twinkyrider
78 kz1000A
Fond du Lac,WI
