KZ 650 Problem (stumbles off idle)
  • onuLine57
  • onuLine57's Avatar Topic Author
24 Jun 2007 22:29
#152471
I bought a 78 KZ650 B2A and I have adjusted the valves replaced the points and condensers and the wires. The carbs have been cleaned and new jets put in. My question is that when I go to open the throttle quickly from idle it will bog down and try to stall. The bike idles fine and runs fine on open throttle but I can’t figure out what the problem is. Does it sound like a carb, ignition timing, of some other problem. One thing that I saw was the bike came with #90 main jets and this seems like it is a little small. Any help would be great.
Post edited by: onuLine57, at: 2007/06/25 13:59
1978 KZ650 B2A
Cincinnati, OH
  • Mark Wing
  • Mark Wing's Avatar
Re: KZ 650 Problem
24 Jun 2007 22:34
#152472
Welcome. The main's seem a little small to me too, I'm not sure but I thought they have 110's but not sure. On the bog you can check the timing advancer to make sure it moves freely.
Mark
Yorba Linda Cal.
  • onuLine57
Re: KZ 650 Problem
24 Jun 2007 22:38
#152473
Ya I saw that WG said that the 78-79 came with ths small jets and that 102s can be put in i think. I was going to pull the advancer off tomorrow and look at it.
1978 KZ650 B2A
Cincinnati, OH
  • yggy
  • yggy's Avatar
  • more wrenching than riding!
Re: KZ 650 Problem
25 Jun 2007 03:21
#152493
Hi there,
sounds to me u might forgot to freshen up the sprakplugs.. (in other words get new ones) I had excactly the same problem . Changed the sparks and hey presto runs like a dream..
1980 EU-z650 c4 one of the few C's around..
  • onuLine57
Re: KZ 650 Problem
25 Jun 2007 08:02
#152539
sorry forgot that...the plugs are new too.
1978 KZ650 B2A
Cincinnati, OH
  • katjbus
  • katjbus's Avatar
Re: KZ 650 Problem
25 Jun 2007 09:10
#152549
when you see a stumble off idle like that from what i have seen you will probably have to adjust the pilot screw since that is what effects that part of the circuit in the carbs
  • onuLine57
Re: KZ 650 Problem
25 Jun 2007 10:58
#152576
I have it set at 1 and a half so im thinking i should turn it in a bit and see if it gets better is that correct?
1978 KZ650 B2A
Cincinnati, OH
  • katjbus
  • katjbus's Avatar
Re: KZ 650 Problem
25 Jun 2007 14:48
#152628
The only way to know is trail and error go in first if it gets worse go the other way
  • vach
  • vach's Avatar
Re: KZ 650 Problem
25 Jun 2007 15:36
#152641
Do you have a header on it and pods? My bike was doing the same thing on the stock 15 pilot. So I put a 17.5 in it and that helped but ended up w/ a 20 and now I'm all good..
1979 kz650 B. Chicago, Illinois
  • onuLine57
Re: KZ 650 Problem
25 Jun 2007 16:24
#152654
no its the stock air box and filter and stock exhaust. There is a small exhaust leak where the header and muffler meet on the left pipe though. Im going out now to play with the pilot screw.
Post edited by: onuLine57, at: 2007/06/25 19:25
1978 KZ650 B2A
Cincinnati, OH
  • kzwolfsr
  • kzwolfsr's Avatar
Re: KZ 650 Problem
25 Jun 2007 18:17
#152668
Mine did the same thing to til I adjusted the air mixture screws just right, but generally I am not sure if these bikes can handle sudden throttle burst like that but be very slight at adjusting air mixtures if you do.
Original man of the Caribbean
  • onuLine57
Re: KZ 650 Problem
25 Jun 2007 19:34
#152693
Alright I closed the pilot screw a bit and lowered the needle one slot and it seems to be a bit better, I will know for sure after work tomorrow. Another problem im having off and on is that when i push the choke down the rpms want to go up on their own. Any ideas on this?
1978 KZ650 B2A
Cincinnati, OH
