Buzzy SR 650, what to look for?
- N0NB
- Blue handles better
24 Jun 2007 17:15
I've now had a chance to road ride two other 650s besides my SR this year. Compared to mine, both of those have been exceptionally smooth with no clouding of the mirrors or buzz through the handgrips, footrests or seat of which my SR has an abundance.
The buzz is directly tied to engine RPM and is the same in any gear at any road speed and is repeatable by RPM. Later this summer I plan to park it for a while and do a few things to it, especially a valve tappet clearance adjustment.
I'm not optimistic that doing a clearance adjustment will make any difference and that it may well be an imbalanced crank. Of course I have no way of knowing unless the whole engine were pulled apart and each rotating part were balanced.
Another culprit that comes to mind would be the flywheel/alternator.
This post is mostly a mind ramble...
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- wiredgeorge
Re: Buzzy SR 650, what to look for?
24 Jun 2007 17:59
Have the carbs been sync'd?
- N0NB
24 Jun 2007 18:25
Sync'd in late summer '04. At the time I noticed no change in the buzz intensity before or after the sync.
I'm guessing this one simply wasn't quite right from the factory.
Nate
- kzwolfsr
25 Jun 2007 19:36
I am sorry to say but you sound like you have a problem. Mine buzzes too but I can still see in the mirrors, big difference from my 1000 that turns lines in the street into fences when I look in the mirror. However its not my 1000's fault and I can't say z1, but those mirrors are flimsy. The stocks are strong but the part behind the mirror is soft. Sorry Nate, just had to get that off my mind.
Original man of the Caribbean
- KaZooCruiser
26 Jun 2007 08:19
Check your sprocket ratios against the other bikes.
Changing the ratio might move the vibration out of the obnoxious range.
- tjettim
26 Jun 2007 09:28
Try tightening all the motor mounts.Make
sure the gas tank rubber mounts are still
soft and in the correct place.Take a com-
pression check and make sure all cylinders
are even.
are even.
- yggy
- more wrenching than riding!
26 Jun 2007 12:11
maybe a long shot but i had the same problem.. but only at 80kmph to 130kmph or so..
Bought a set of these:
for 10 dollars, and gone was the buzzing of the steer and the mirrors.. best buy i did
1980 EU-z650 c4 one of the few C's around..
- WABBMW
- Let The Good Times Roll !
26 Jun 2007 20:19
Nate:
My 82 KZ650 CSR develops a simple harmonic vibraton between 4300 to 4900 RPM. My bike has a 13 tooth front sprocket and 33 tooth rear. So the vibration is between 53 and 59 MPH in 5th gear. It is in sync with the tach, and can easily be felt when in neutral or any gear. It is not bad enough to blur the mirrors. I believe that nothing is wrong, but simply a characteristic of these 4 cylinder engines. I could be wrong.
Now I do hear some buzzing sounds occasionally coming from the baffles in the mufflers but have not established any pattern to it. It is a "sound", whereas the first paragraph describes a "feel".
I am curious if anyone else has this same phenoninon?
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
- OKC_Kent
27 Jun 2007 05:11
I get a severe buzz from my gas cap lock at speeds upward of 60-65. My left mirror is good to about 60 then gets fuzzy. My right mirror is fuzzy all the way to 80 then gets clear as can be.
Cashion, OK
78 KZ650 B2 85,000+ miles
- bill_wilcox100
27 Jun 2007 05:37
yggy: "Maybe a long shot but I had the same problem.. but only at 80 kph to 130 kph or so... Bought a set of these for 10 dollars, and gone was the buzzing of the steer and the mirrors.. best buy I did".
Sorry, incoming dumb question... what are "these" anyway?
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
- BSKZ650
27 Jun 2007 06:12
they are harmonic dampners, they go in the ends of the bars. I think its the same thing used in anti vibration boring bars
77 ltd1000, current rider
76 kz900, just waiting
- bill_wilcox100
27 Jun 2007 10:12
BSKZ650, don't mean to hijack this thread but do you have a web site for these guys? Sounds neat and from the input above they actually seem to work... cool. Thanks.
Upgrades:
Montreal, Canada
Upgrades:
Montreal, Canada
