Buzzy SR 650, what to look for?
- BSKZ650
Re: Buzzy SR 650, what to look for?
27 Jun 2007 13:37
I will do some looking tonight
77 ltd1000, current rider
76 kz900, just waiting
- N0NB
- Blue handles better
28 Jun 2007 05:09
tjettim wrote:
Good points. Although the tank mounts shouldn't make much difference to the buzz felt in the seat and foot rests. I plan to do the other checks when I do the valve clearance check.
My sprocket ratio is 16/38 which helped to move the buzz up in MPH from the stock 16/41 ratio. On the 650B and the project SR I went up one tooth on the front to 17 while leaving the rear stock at 42 and 41 respectively.
The buzz in the seat is really the problem area as certain areas get numb. :blush:
Try tightening all the motor mounts.Make
sure the gas tank rubber mounts are still
soft and in the correct place.Take a com-
pression check and make sure all cylinders
are even.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- BSKZ650
28 Jun 2007 14:04
what about the wheel bearings, front and rear, also have you had the tires rebalanced, may not be a engine thing since it seems to be mph related
- N0NB
28 Jun 2007 14:33
It's not MPH related. It's directly related to engine RPM and is reproducible in any gear. Run at 70 MPH indicated, tach at 5400 RPM and mirrors are clouded, pull in the clutch and let engine idle and mirrors clear right up and buzz goes away.
That was one of my first tests early on when I first got it back on the road and noticed the buzz.
It's still less buzzy than my KL250 was!
Nate
- BSKZ650
28 Jun 2007 15:59
well damn another idea shot to hell:(
- PLUMMEN
28 Jun 2007 19:34
oops,i thought scrapper was looking for a 650 for his fly!:blush: :woohoo:
