bench shimming?? APE
- MkII
16 Jun 2007 07:01
I just recieved my head back from APE that had a note to bench shim it prior to installation. I'll call them on Monday but thought I could probably get a few tips from the crew here. Is this to be performed any diff than if it was installed??
New valves, guides, seals, std. valve job should def. help bump comp. back up. Waiting on jugs back from them bored for 1075, going to run stock cams and carbs for now with their 10.25:1 pistons.
1977A1 current project: 1075, Web cams, VM29's Cavanaugh massaged head, Z1 crank
1979A3A Parked in 1986 left in shed
Phx,Az
Phx,Az
- APE Jay
Re: bench shimming?? APE
16 Jun 2007 15:49
Yes, Just like if it was on the engine. The reason we put that note in there is in the off chance we would have a valve length out of the shim range, you would like to find out before the head was on the motor.
How did you like the way it came out?
Jay
Jay
- Kiwiz
16 Jun 2007 15:59
This might seem like a completely idiotic comment but when you bench shim you do it without the valve springs installed!
Being a complete moron I couldnt understand how you could rotate the cam against the spring tension until someone told me: DOOOH!
Hold the valve into the seat with your fingers rotate cam until appropriate lobe is away 180deg. away from shim and measure. Once shim size sorted refit valve gear as normal hopefully not mixing up shims.
Highly recommended if valve seats have been reground. Nothing worse that putting head on to find no shim is small enough
- pstrbrc
- '81 GPz 1100 project
16 Jun 2007 15:59
Bench shimming? My Clymer says that's a big no-no because of the possibility of bending valves, but it seemed to me to make sense to do this 'cause you could do it on the bench, for Pete's sake, not struggling around the frame. So, do I put the block on the bench, set the head on that, then install the cams? Should I do it one cam at a time, so I don't get interference between intake and exhaust valves? What is the suggested way to turn the cams?
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
Elkhart, Kansas USA
- Kiwiz
16 Jun 2007 16:03
If you do it the way I suggest you only have one valve in the head at a time.
Based on my experience this works pretty well. When I refiited my J head 6 months agon I checked once it was fitted to the bike after having undertaken this procees. Only one shim needed to be swapped further
- Duck
- e vica na i sau na ga
16 Jun 2007 17:45
I just lapped valves on my 1100 head and managed to get the shims all mixed up so I went through measuring all with a thin one, figured out what went where, and measured again to be safe.
Process follows...
Make sure everything is clean!
Stick a bucket and shim in a hole.
Stick the valve in the other end.
Drop the camshaft in.
Makse sure valve and camshaft are seated.
Measure the clearance.
WRITE IT DOWN.
Move on to the next bucket-valve
Post edited by: Duck, at: 2007/06/16 20:47
Process follows...
WRITE IT DOWN.
- KZQ
- Administrator
19 Jun 2007 18:33
Bumped to the head of the line for the benefit of atp.
atp,
Did you search first?
KZCSI
atp,
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- nads.com
20 Jun 2007 00:18
torque the cams to at least half the spec before measuring for shims. You want to be right on not pissed off.
- MkII
21 Jun 2007 15:57
I bench shimmed the head today and need to call Jeff to obtain more 2.80 and 2.90 shims, otherwise it looks to be in spec once the proper shims are in. only slight gripe is they(APE) electric stencil what looks to be a job# on the head on a highly visable fin by the plug location, I wished they would have found a less obvious place to stencil this # on or use some other method. little gripe otherwise looks fine.
Phx,Az
Phx,Az
- themachine
21 Jun 2007 17:27
yeah, i have to run 2.20 shims on two of my ehaust valves
i want to get new/bigger seats, valves, and guides next winter :B
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- APE Jay
21 Jun 2007 20:54
MkII wrote:
Training Mike to writye the numbers on the bottom where they won't be seen when the engine is assembled.
You are right about it being a work order number. Every part we get in the shop gets a number as soon as we unpack it. We never have to pick up a block, head, or crank, etc. and try and guess who it belongs to. This way we never mix up customers parts.
Your block and pistons are on the way. ( I hope the number is on the bottom:whistle:
Jay
Post edited by: APE Jay, at: 2007/06/21 23:56
Jay
- themachine
22 Jun 2007 19:36
APE Jay wrote:
so, does APE Jay have any ol kz's in his stable at home?MkII wrote:I bench shimmed the head today and need to call Jeff to obtain more 2.80 and 2.90 shims, otherwise it looks to be in spec once the proper shims are in. only slight gripe is they(APE) electric stencil what looks to be a job# on the head on a highly visable fin by the plug location, I wished they would have found a less obvious place to stencil this # on or use some other method. little gripe otherwise looks fine.
Jay<br><br>Post edited by: APE Jay, at: 2007/06/21 23:56
