- Thank you received: 16
Base Gasket Removal
- kzwolfsr
Original man of the Caribbean
- wireman
- Visitor
- Thank you received: 2098
- FloridaBiker
- Thank you received: 4
I buy a product from NAPA called ROLOC.
It is like a scotch-brite pad on a 2" arbor.
It removes all gasket residue without harming the case.
Roloc is a brand name, and they also make sanding discs on arbors, make sure you get the brown pads that look like scotchbrite
WARNING: Wire wheels WILL remove and/or scratch the case material, making them leak.
I jist looked at the box, and they are by Scotchbrite
Post edited by: FloridaBiker, at: 2007/06/13 16:32
- FloridaBiker
- FloridaBiker
- kzwolfsr
- FloridaBiker
I don't own stock, so no apology necessary.Sorry Florida but I don't feel like it for dust or dirt around that area right now, and my nose, have a slight cold. And acetone sounds like another good idea Wireman.
Acetone may give the old sinuses a workout.
Post edited by: FloridaBiker, at: 2007/06/13 16:36
- Duck
- e vica na i sau na ga
Never tried Permatex Gasket Remover, but might be worth taking a look
This stuff will strip the paint from your case.
Post edited by: Duck, at: 2007/06/13 16:38
- kzwolfsr
- FloridaBiker
Yes, get high temp enamel from the auto parts store. The Very High Temp paint is only needed for exhaustI don't have any paint on my engine (thank God for that). I am going to go looking for it now. Where to start? Any auto store?
- steell
This stuff will strip the paint from your case.<br><br>Post edited by: Duck, at: 2007/06/13 16:38
It will also cause your cam chain, rods, and cylinder studs, to start rusting almost immediately. I tried it once
