Base Gasket Removal
- kzwolfsr
Base Gasket Removal
13 Jun 2007 11:58
Ok you pros out there, how do I remove the old base gasket, cylinder base gaskets, with the engine still in the frame and without dropping anything in the cases? I wire wheels the crap of the bottom of the cylinders already, but I dont think, unless I clog the holes before I wire wheel the cases side, but give me your suggestions!
Original man of the Caribbean
- wireman
Re: Base Gasket Removal
13 Jun 2007 12:17
stuff holes full of rags,soak gasket with acetone and start scraping;)
- FloridaBiker
13 Jun 2007 12:45
I do this often.
I buy a product from NAPA called ROLOC.
It is like a scotch-brite pad on a 2" arbor.
It removes all gasket residue without harming the case.
Roloc is a brand name, and they also make sanding discs on arbors, make sure you get the brown pads that look like scotchbrite
WARNING: Wire wheels WILL remove and/or scratch the case material, making them leak.
I jist looked at the box, and they are by Scotchbrite
Post edited by: FloridaBiker, at: 2007/06/13 16:32
- FloridaBiker
- FloridaBiker
13 Jun 2007 13:20
They are available with sticky back or with the twist arbor.
Don't bother with the sticky back, they think they are flying saucers, and escape often.
- kzwolfsr
13 Jun 2007 13:27
Thanks guys But I like Patton's idea better, never heard of it. Sorry Florida but I don't feel like it for dust or dirt around that area right now, and my nose, have a slight cold. And acetone sounds like another good idea Wireman. Thanks guys! I thought people stay away from my post seeing how long they take to give me an answer. Just came in from working on 650 clutch again, I let my girlfriend learn how to ride it so its getting a fair share of abuse!
- FloridaBiker
13 Jun 2007 13:35
kzwolfsr wrote:
Acetone may give the old sinuses a workout.
Post edited by: FloridaBiker, at: 2007/06/13 16:36
I don't own stock, so no apology necessary.Sorry Florida but I don't feel like it for dust or dirt around that area right now, and my nose, have a slight cold. And acetone sounds like another good idea Wireman.
- Duck
- e vica na i sau na ga
13 Jun 2007 13:36
Patton wrote:
This stuff will strip the paint from your case.
Post edited by: Duck, at: 2007/06/13 16:38
- kzwolfsr
13 Jun 2007 13:44
I don't have any paint on my engine (thank God for that). I am going to go looking for it now. Where to start? Any auto store?
- FloridaBiker
13 Jun 2007 14:04
kzwolfsr wrote:
Yes, get high temp enamel from the auto parts store. The Very High Temp paint is only needed for exhaustI don't have any paint on my engine (thank God for that). I am going to go looking for it now. Where to start? Any auto store?
- steell
13 Jun 2007 14:58
Duck wrote:
It will also cause your cam chain, rods, and cylinder studs, to start rusting almost immediately. I tried it once
Patton wrote:
This stuff will strip the paint from your case.<br><br>Post edited by: Duck, at: 2007/06/13 16:38
