HELP!!!!!! Camshaft bolt hole stripped
  • jcote75
  • jcote75's Avatar Topic Author
07 Jun 2007 19:17
#147312
Need fast help!
Wanted to torque the bolt to 12 lbs. Everything was going fine but I've discovered that one of them was strip................
Thread are still there but too loose to torque at 12 lbs.
Is their a soft metalic shime that I can insert or anything else to fix this!!!!!!!!
It will be sunny all week-end and I won't be able to ride :(
Please give me some good advise.
Joce
  • badboie
  • badboie's Avatar
Re: HELP!!!!!! Camshaft bolt hole stripped
07 Jun 2007 19:22
#147317
I dont know of anything off hand so I am not much help lol. the only advice I can give you since its friday tomorrow is to justr go to and pick up a new bolt. Can't it wait till tomorrow? sorry dude :ohmy: :(
  • KZQ
  • KZQ's Avatar
  • Away
  • Administrator
  • Administrator
07 Jun 2007 19:23
#147318
Go to NAPA and get a timesert. You'll be back on the road in an hour.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • badboie
  • badboie's Avatar
07 Jun 2007 19:26
#147320
well I suggest tomorrow because Me thinks NAPA might be closed :huh:
  • jcote75
07 Jun 2007 19:27
#147321
Thanks for your comprehension....It's not the bolt the problem but the that the bolt goes in.
I'll try the timesert.
I will have better sleep....
  • RonKZ650
  • RonKZ650's Avatar
07 Jun 2007 19:41
#147326
If your camshaft bolts are the standard 6mm, meaning a 10mm socket is used, 12 ft/lb is too much by about twice. You'll strip them all before long.
07 Jun 2007 20:03
#147341
What reference advised 12 FT LBS? I didn't notice what model bike you're working on, but the shop manual calls for 95 - 113 IN LBS (that's 7.9 - 9.4 FT LBS) on cam cap bolts for KZ650. RonKZ650 is correct, if you try to tighten them all to 12 FT LBS, you'll soon ruin the rest. Suggest you buy a shop manual and quality small size torque wrench (that is one that is graduated in inch pounds). Ed
  • jcote75
07 Jun 2007 20:07
#147342
I got the Clymer manual
The bike is a 1984 z1100R
Camshaft cap bolts: 12 ft.lb
Maybe I'm not reading this right or my torque wrench need to go to the garbage..............:blink:
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
07 Jun 2007 20:53
#147353
That's like 144 INCH pounds...WOW!
Back that off to about 8 foot pounds,for sure.(maybe 9)
When You're dealing with such small torques like that,You're WAY better off to be using an INCH-pound torque wrench,Bud...WAY more accurate that a foot-pound wrench.
1977 KZ1000 A-1
  • dadams7161
  • dadams7161's Avatar
  • live to Ride Lifes Better on the Road in the wind
07 Jun 2007 22:00
#147368
helicoil set will work you have to drill the threads out tap it and insert the helicoil you can find them here www.emhart.com/products/helicoil.asp or here is another link www.emhart.com/products/helicoil/repkit.asp
Post edited by: dadams7161, at: 2007/06/08 01:02
1982 KZ750-M1 CSR Twin
3rd Owner of this Jewel
Before and After Photos
  • themachine
  • themachine's Avatar
08 Jun 2007 05:30
#147418
should i use locktight or oil on the cam cp bolts?
has anyone ever had theirs come loose?
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
  • reborn650
  • reborn650's Avatar
08 Jun 2007 06:39
#147437
I just did 2 bad cam cap bolts last night on my 650. I am slowly finding all the f*ckups the guy that owned the bike before me did including a bad spark plug helicoil and 2 poorly installed cam cap helicoils.
The stripped bolt holes are probably on the exhaust side I would bet as these are more likely to give up the ghost before the intake.
I picked up a recoil (same as a helicoil) kit that included the tap for the 6 mm bolt, 12 helicoils with a thread pitch of 1 to match the cam bolts and the installation tool. Read the instructions carefully before you proceed as it is easy to ruin the head.
You will need to drill out the old threads and if I am not mistaken you will use a 1/4 bit for a 6 mm bolt. Measure with a digital caliper (the extended end how far you need to drill down. You don't want to go all the way through the head with the drill, only down far enough to get to the base of the existing threads.
Once you have drilled the opening for the new helicoil, spray some carb or brake clean down the new hole to clean out the metal shavings from drilling.
Grab the tap that comes in the kit, put a little dab of grease on the tap ridges and carefully screw the tap into the drilled hole. You will need to put pressure on the tap to cut new threads into the hole. The grease will collect most of the shavings when the tap's teeth cut new threads.
Clean the hole again with Q-tips to get all of the shavings out and take a look to make sure they are clean and straight or the bolt will not seat properly. You will probably need to clean the areas around the lifter buckets to ensure you don't get any shavings floating around the top end of the engine.
The final step is to use the tool to screw in the helicoil. Make sure it goes to the bottom of the hole or the cam cap bolt will not make it all the way to the shoulder and sit the cam cap flush on the head.
Test the helicoil with a cam cap bolt to ensure you drilled the hole and set the helicoil in straight.
When installing the cams and caps do not torque the bolts more than 8-9 ft. lbs or you might be doing the job all over again.
Do not use any type of Loctite as you will eventually need to remove the bolts to pull the camshafts to do a valve shim job.
-1998 Jeep TJ Wrangler 4.0 litre for the kids
-1975 Zamboni - The real Italian sportscar fully restored and functioning every winter at our local outdoor playground rink.
Mine is an ecclectic collection of motorized toys - LOL
I have a newspaper route and a web site where you can plan your own funeral life celebration www.mysendoff.com ....and go out with your own style.
