This doesn't look right (PIC)
  • donthekawguy
  • donthekawguy's Avatar Topic Author
01 May 2007 21:03
#136320
the bigger part is the new one from Jeff. The rest of the other one is down in the motor somewhere. :(
img.photobucket.com/albums/v683/donthekawguy/drag008.jpg
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • vach
  • vach's Avatar
Re: This doesn't look right (PIC)
01 May 2007 21:08
#136324
What is that? I'm trying to picture it but, I can't.
1979 kz650 B. Chicago, Illinois
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
01 May 2007 21:15
#136329
Looks like a broken cam chain guide to me, most certainly not a good thing. :S
That sucks Don. :(
Have you tried pulling the oil pan to see if it made it past everything else without causing damage and ended up there?
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • Pterosaur
  • Pterosaur's Avatar
01 May 2007 21:16
#136330
Cam chain follower.
Well, ain't that special? :cheer:
Actually, I've seen the whole mess drop out and go swimming in the pan and run for who knows how long before getting fished out. :huh:
Amazing machines. :whistle: B)
  • donthekawguy
01 May 2007 21:22
#136334
It's the guide in the middle of the cylinders. I started it up to move it in the garage a month or so ago and it ran fine. I think I got lucky and the chunck fell into the pan. I'm pulling the pan off Thursday and hoping it'll just fall out.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
  • Mcdroid
  • Mcdroid's Avatar
  • Away
  • Gone Kwackers
01 May 2007 23:02
#136353
Don,
If your motor hasn't been apart for a long, long time, then what you see is not surprising. That is a very common wear pattern and I predict you will find little more than itty bitty chunks in your oilpan. While I haven't had alot of 1000 motors apart, all the early model 1000's had this type of worn guide:). Replace all the internal rubber adjusters in your motor.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • MDawnz1
  • MDawnz1's Avatar
01 May 2007 23:10
#136355
Just a busted guide ,,,,,,,
The question is ??
Where did the wrest of it end up ?
Just kidding B)
1974 Z1a, still 903
  • donthekawguy
01 May 2007 23:22
#136359
I'll take a pic when I get the pan off. Maybe even a video! I don't think the motor has ever been apart so it should be interesting to see whats inside.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
  • rattler
  • rattler's Avatar
01 May 2007 23:32
#136361
ouch...:blink: i had the same thing happin the day after i bought the kz i ride now for my father some years ago. i got lucky and it was pretty much two big pieces but there was some small debree like mcdroid stated in the oil pan along with a bunch of motor sludge. the cases were split was cleand up and a lot of new parts were insatlled that were found to be wore along the way. while you are in there it might be a good idea to go ahead and replace the cam chain, camchain rollers, ect...
  • donthekawguy
02 May 2007 01:49
#136374
I was trying to avoide a total rebuild this year but it's looking like I'm headed that way.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
  • indykaw77
  • indykaw77's Avatar
02 May 2007 04:57
#136384
I'll be 1st to admit I AINT the sharpest crayon in the box......but THAT dont look good!!:blink:
Anxiously awaiting the "After" pics..........
Kawasaki Motorcycles...because cars lean th wrong way!
  • brianrae33
  • brianrae33's Avatar
02 May 2007 06:30
#136400
had the exact same thing happen to me only there was even less of my guide left then yours....never had any problems with it affecting internals since the original guide is all rubber except where it slides into the notches...had tiny black pieces of rubber for about 2 or 3 oil changes afterwards:P but doesn't seem to have affected anything...
1982 kz1000ltd
