- Thank you received: 1
Supposed to have 2 throttle cables?
- 13thlevel
- arobsum
- Thank you received: 10
- Pterosaur
- Visitor
one push and one pull (for safety or backup i would assume) in a pinch i have taken one off when the other one broke, used it on the other side and drove it this way for quite a while.
What he said.
Having that second cable has saved me on the side of the road a long way from the barn a couple of times as well.
The earlier Z/KZ vintage throttle setups seem to be tough on cables - I've snapped 4 out on the street over the years to memory - aside from the ones I've spotted in the nick of time. I've lubed, taken down hard edges on the twist-pulley with a dremel, all that stuff, and the cables still fray over time. Good idea to have that second cable and make a visual inspection part of the yearly inspection.
Sad to say, but throttle cables are waiting to go off on these birds...
- RonKZ650
- Thank you received: 240
- wireman
- Visitor
- arobsum
- RetroRiceRocketRider
- Thank you received: 29
I guess-timate I've got around 40K with this setup, and frequently inspect/lube the inner cables and barrel ends. Perhaps your cables were routed to where it caused them to bind, Ron?
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- wireman
- Visitor
- themachine
- Thank you received: 4
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- arobsum
its been the speedo with me, for some reason my bike has went thru 2 so far.you guys just arent trying hard enough!!!!! i suppose lubing the cables does help,i should try that some time! i used to eat a lot of tach cables also,but they are a lot easier to oil than throttle cables;)
- Bluemeanie
