- Thank you received: 12
Can you use Restore when u change oil?
- oldkaws4ever
- Have no regrets...... You only live once.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- 77KZ650
- Thank you received: 7
07 MDP Rookie of the Year
- AR15Ron
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- kzwolfsr
- Thank you received: 16
Original man of the Caribbean
- Pterosaur
- Visitor
Teflon-goo don't do a clutch much good.
Don't know anything about "Restore" in particular, but I think the only thing stuff like "Marvel Mystery Oil" does is *restore* profits to miracle-cure peddlers from the pockets of people hoping for a quick-fix.
Nothing beats good oil and a good filter.
- RonKZ650
- Thank you received: 240
Nothing
Clutch worked exactly as before, oil consumption was exactly the same as before.
I still wouldn't use it though, mostly because of the nothing part.
- AR15Ron
- Pterosaur
- Visitor
Over the years I've used Slick 50, STP oil treatment and the like and had the horrendous experience of
Nothing
That's probably because you changed your oil at least once a decade.
And you're probaby not an every red light *Hole Shot Andy Warhol*, either.
A slight omission in my previous was that after dumping in the Slick, the owner of the aforementioned POS thought his oil-changing days were over - as well as most other forms of maintenence.
Aside from the teflon dropping out of suspension and making some very pretty sludge around the oil pump pickup, the clutch plates were an ice skater's dream.
So yeah, I could see where the Slick wouldn't overtly screw up a decent motor operated decently - but the overwhelming majority of people that go for Miracle Cures (tm) have already thrashed a motor into a state that'd qualify as crimes against engineering anyways.
Saw a Ford Van motor with 300,000 on the clock fried alive in its own oil when a guy bought it from a fleet operation and dumped Sick 50 in it - teflon merged with the sludge in the journals and pretty prevented oil from getting anywhere it was designed to go.
So go ahead and run it. I'll pass.
- pyxen
Thanks!
84 KZ550-F2 LTD
93 ZR550-B4
- RonKZ650
The wet clutch and additives thing is mostly just a liability thing and the fact companys don't care to test the products with a wet clutch since it's not a major market for them.
- Pterosaur
- Visitor
It's kind of hard to imagine Slick50 doing any harm. It's been a long time but wasn't Slick50 basically 95% oil and 5% additives some of which was teflon? This mixed 1 quart in an oil change of 5 quarts would net about a 1% total teflon in the system or so at the most.
Well, as I said before, the nightmares I've seen it cause were in older motors where some genius figured he'd get a $19.95 overhaul-in-a-can.
ANY inert partiulate you cram into a sludged-up motor is gonna add to its problems.
I'd suppose that's true.
But what I'm more worried about is *you* - you feeling okay? For such a normally dyed-in-the-wool OEM kinda guy, you're sure taking an *aftermarket* stand on things...
