Cylinder Head Surface Damage Question.
- CoreyClough
- GPz550 Addiction
09 Apr 2007 05:15
The Cylinder Head has surface damage on it from shipping. APE graciously rebuilt it about a year ago, along with cylinders transformed into a 615 Wiseco Kit, and then I sent it to a friend of mine for port and chamber cleaning/work. In the process of shipping it, and some other stuff, the picture below tells the story. Any recommendations in a repair, or just leave it as it. This head is going on a 615 kit I have been slowly working on.
Any feedback would be appreciated.
This one above, that's close to the combustion chamber concerns me the most.
'85 GPz550(ZX550-A2)
- BSKZ650
Re: Cylinder Head Surface Damage Question.
09 Apr 2007 05:59
cant tell how deep the marks are, but they look like they need to be repaired, you may have to have someone tig weld the spots and then have the head resurfaced
77 ltd1000, current rider
76 kz900, just waiting
- kzwolfsr
09 Apr 2007 06:19
I second that
Original man of the Caribbean
- CoreyClough
- GPz550 Addiction
09 Apr 2007 07:29
Thanks for the advice.
I guess the other thing I can do is line up the head gasket, and see if it's covered or not, but I'd be willing to send(better packed this time) it out rather than take a chance.
- BSKZ650
09 Apr 2007 14:26
even if the gasket clears the damage, there is still going to be high and low spots on the head, at a bare min, I would get it milled to get the highs out
- KaZooCruiser
09 Apr 2007 14:43
My .02 They look worse than they probably are. The gasket is going to seal pretty much everything. It's an air-cooled engine. No water jacket to be compromised by a scratch. I don't make a recommendation here, but I know there are sealants "copper permatex" that is supposed to help in cases like this.
- wireman
09 Apr 2007 15:16
through it on there with a good gasket and run it;)
- BSKZ650
09 Apr 2007 15:43
dont forget that a gasket is only going to crush so much, if you have a high spot then that area will crush and torque, but the rest of the area will not be sealed as well as it should, also if you want the cheap way, take a large flat bastard file and go over the head,
- CoreyClough
- GPz550 Addiction
09 Apr 2007 15:49
Remember this head is going with a 615 kit that's now 10.25:1 compression. I'd like not to have to mill the head for even higher compression, as the edges of the valves are right at the ends of the combustion chambers. If any more were to be milled off, the valve would need to be ground down to compensate.
I appreciate your replies, and will think about them before I make a decision.
- APE Jay
10 Apr 2007 23:47
Lay the gasket on it and see if it clears the metal ring in the gasket. If it does, you are OK.
Jay
Jay
- CoreyClough
- GPz550 Addiction
11 Apr 2007 05:19
So, if the damage is visible when gasket is in place it, or if the metal ring covers the damage... :S
- RetroRiceRocketRider
11 Apr 2007 05:25
Corey,
I think what Jay is saying is, through the gasket on there and see if the metal rings themselves aren't directly on one (or more) of the damaged spots and therefore compromising it sealing properly.
From what I understand, the metal rings are what do the bulk of the sealing for the expansion chambers/cylinders, the rest is basically just "cushion" and to seal around the oil ports - not a lot of pressure runs through those oil ports.
Post edited by: RetroRiceRocketRider, at: 2007/04/11 08:27
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
