Engine Forum
Engine forum is a tech forum for "Engine" topics.
Needle Bearing Clutch Pusher
  • 79MKII
  • 79MKII's Avatar Topic Author
  • Love Them Kaws!
Re: Needle Bearing Clutch Pusher
11 Apr 2007 18:05
#128958
bill_wilcox100 wrote:
On the Z1 site, in the picture provided, I can only see one washer for this model:
www.z1enterprises.com/detail.aspx?ID=257
Curious... is there more than one supplier? This seems to be made by APE.
That one looks like steel. Others I've seen are billet. Maybe the ones with a steel pusher only need the washer on the pressure plate side?
My pusher is totally flat and made of steel and the hardware bolts to the pressure plate. I just hope it's OK with one washer:S
Hopefully Jeff or Ape Jay will chime in...
Post edited by: 79MKII, at: 2007/04/11 21:07
The Kaw List:
  • N0NB
  • N0NB's Avatar
  • Blue handles better
11 Apr 2007 18:29
#128978
I'm going to guess that the washer goes between the pressure plate and the needle bearing. Since your pusher is already steel, it makes sense to me.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
11 Apr 2007 18:55
#128995
Look again at that picture...there is one washer already ON the unit,and another one laying BESIDE the unit.
1977 KZ1000 A-1
  • Ron G
  • Ron G's Avatar
11 Apr 2007 19:52
#129035
Make sure that the pusher doesn't contact the boss that supports the thrust bearing. If it does then another washer should be placed on the boss between the thrust bearing and the pusher.
Ron G
  • 79MKII
  • Love Them Kaws!
12 Apr 2007 04:29
#129145
Good eye Sandy! That puts a serious dent in my "one washer might be OK" theory! I'm nearly positive that mine has had only one washer since it was installed 20 years ago. I wish I had thought of checking into it BEFORE it put everything back together!!:blush:
The Kaw List:
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
12 Apr 2007 08:39
#129225
Well 79MK11...just so You know,You MIGHT be able to re-use that gasket,if You have to remove the cover.I did,and it held together,and no leaks at all.
1977 KZ1000 A-1
