Needle Bearing Clutch Pusher
  • 79MKII
  • 79MKII's Avatar Topic Author
  • Love Them Kaws!
07 Apr 2007 21:30
#127581
Well, so much for my memory. :S I can't remember exactly how my needle bearing goes in for the clutch pusher. Mine is a little different because the needle bearing installs on the pressure plate and uses the stock pusher.
The question is, where does the thrust washer go? There was only 1, not 2 as I've seen with the pusher kits. I think the thrust washer goes between the bearing and the pressure plate. Does this sound right?
BTW, where would the washers go in the regular needle bearing clutch pushers anyway? One on each side of the bearing?
Thanks
Post edited by: 79MKII, at: 2007/04/08 00:32
The Kaw List:
  • 79MKII
  • Love Them Kaws!
Re: Needle Bearing Clutch Pusher
08 Apr 2007 18:41
#127854
Anyone have one of these or the pusher type??
The Kaw List:
  • kzwolfsr
  • kzwolfsr's Avatar
09 Apr 2007 06:24
#128049
Did you check parts diagrams?
Original man of the Caribbean
  • 79MKII
  • Love Them Kaws!
09 Apr 2007 07:35
#128072
Great idea, but the needle bearing pushers are aftermarket, so I don't have a diagram. I did some searching for what it offered now and they all seem to include 2 thrust washers. I doesn't make sense to me to have a washer between the bearing and the pusher, but maybe that's where mine should have gone?? I put it between the pressure plate and the bearing. (It's under the bearing in the photo above).
These are such a popular add on that I thought I'd have all kinds of advice on this one.
The Kaw List:
  • 79MKII
  • Love Them Kaws!
10 Apr 2007 19:06
#128648
Delete
Please see next post
Post edited by: 79MKII, at: 2007/04/10 22:10
The Kaw List:
  • 79MKII
  • Love Them Kaws!
10 Apr 2007 19:11
#128651
OK, the picture below is the pusher, bearing, and 2 washers. Where do the washers go? What if you only have one washer? Someone's gotta know this.
The Kaw List:
  • indykaw77
  • indykaw77's Avatar
10 Apr 2007 19:43
#128665
Go to
www.redlinecycle.com
They sell a bunch of them, and have been really helpful on the phone (with me, anyways) in the past.
Good luck.....post the "fix-it" when you get done....
Kawasaki Motorcycles...because cars lean th wrong way!
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
10 Apr 2007 20:36
#128687
Hmmm...I have one installed,and if I'm not mistaken,You put the needle bearing plate in between the 2 washers. (on the aftermarket one.)
If You think about it,it makes nothing but sense,doing it that way.B)
I bought Mine from Jeff,so maybe He'll chime in...
1977 KZ1000 A-1
  • Ron G
  • Ron G's Avatar
11 Apr 2007 11:20
#128822
The washers are the race for the thrust bearing.
Ron G
Post edited by: Ron G, at: 2007/04/11 14:23
  • 79MKII
  • Love Them Kaws!
11 Apr 2007 14:18
#128874
Ron G
<br><br>Post edited by: Ron G, at: 2007/04/11 14:23
That makes sense but I wonder if my type of pusher needs 2 washers?? It has only had one for as long as I can remember:blink: I think the washer needs to protect the aluminum pressure plate, but the bearing should be OK against the steel pusher, right?? I hope anyway...:unsure:
The Kaw List:
  • KaZooCruiser
  • KaZooCruiser's Avatar
11 Apr 2007 14:40
#128886
. . .maybe you got shorted a washer in your kit.
:unsure:
  • bill_wilcox100
  • bill_wilcox100's Avatar
11 Apr 2007 17:57
#128948
On the Z1 site, in the picture provided, I can only see one washer for this model:
www.z1enterprises.com/detail.aspx?ID=257
Curious... is there more than one supplier? This seems to be made by APE.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
