Starting a 77 kz1000 engine-what is needed?
- kirmit77
07 Apr 2007 13:17
i was wondering what is needed electrically to start my 77 kz1000 engine. currently i am puttin this engine in a project and am not goin to use the frame or anything like that. i have the starter and solenoid.
- wiredgeorge
Re: Starting a 77 kz1000 engine-what is needed?
07 Apr 2007 14:10
Ignition, battery, coils, wiring, a switch, some fuses, a reg/rec, etc... what are you looking for?
- AR15Ron
07 Apr 2007 14:13
Do you have the wiring harness from the bike? You will need ignition voltage for coils, regulator rectifier from stator to charge battery. If you have the complete bike and go under the left side cover where the start solenoid is. I think you will only need the wiring from the blue and white conenctors and just rewire the coils to a switched power and a switch for the solenoid to start it. If you have the harness you could probably unplug the other stuff and take the whole plate with the regulator recitfier and fuse panel out with all the connections intact. What exactly are you working with to start?
- kirmit77
07 Apr 2007 14:51
well i am probably puting this engine in a golfcart or a gokart, i have all engine parts and cover etc. i just need i guess coils and so forth, but i do not know what to get
- Duck
- e vica na i sau na ga
07 Apr 2007 15:04
You can find a wiring diagram on line. IIRC there is one in the filebase which is under the kz information heading on the forums tab bar.
If you're not just hacking, it's a good idea to get the factory service manual. Try addall.com for used.
If your frame is straight and has a title and you're not too far from Atlanta, I'd be interested in it.
-Duck
-Duck
- kirmit77
07 Apr 2007 15:48
what is IIRC and im in texas, no title on the bike.
i need anything to do with spark plug wires and coils. where do i find that cheap?
- AR15Ron
07 Apr 2007 15:52
IIRC = if i recall correctly
You will need more than just coils, but you can get new coils at Z-1 for $120. You are also going to need the regulator/recifier if you plan on charging the battery. That will be a little tougher, but aftermarket ones are available I think. I take it you do not have the wiring harness from the bike then? Life would be much simpler if you could just hack apart the wiring harness and take the whole electrical panel with you. I think anyway.
Ron
Ron
- kirmit77
07 Apr 2007 16:17
ok i have the electrical panel,battery, starter relay and starter and ignition switch.
i know this for fact.
im new at the motorcycle thing so what is the essentials now for getting it to start, the bare minimum.
- rodneyo
07 Apr 2007 21:33
Wire it up old school.You know like an old harley.With a point ignition you can do it easy.
- kirmit77
07 Apr 2007 21:39
how do i do that? please tell
- wireman
07 Apr 2007 21:57
get it mounted up in your project and find a good spot to mount your electrical stuff then just connect the dots,if you dont run any lighting or anything like that it will be really simple;)
- kirmit77
07 Apr 2007 22:01
ok im a little dumb on this subject but, when you say connect the dots, what exactly do you mean? how will i get spark to the engine?
