red loctite on cam bolts?
- ronjones
07 Apr 2007 10:06
Did I read somewhere here that it is advisable to put anti-sieze on the lower theads of the cam bolts and red loctite on the upper threads?
Thanks
Ron
Thanks
Ron
- BSKZ650
Re: red loctite on cam bolts?
07 Apr 2007 10:45
are you talking about the cap bolts?
if so I would not put either on them, I would be using some high pressure assembly lube on the bolts,
anti sieze will not let the bolts tighten properly, locktite on the other hand will make it hard to take back apart without causing damage
77 ltd1000, current rider
76 kz900, just waiting
- Mcdroid
- Gone Kwackers
07 Apr 2007 10:54
Well, you might find some disagreement amongst members, but I wouldn't use any Loctite on camcap bolts. The KHI manual doesn't recommend any loctite-type product for camcap bolts.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Mark Wing
07 Apr 2007 11:27
NO!
Yorba Linda Cal.
Yorba Linda Cal.
- ronjones
07 Apr 2007 11:28
OK, cool, I thought I read a thread about striping cam threads and it was recommended to use anti-sieze because of stainless bolts going into aluminum heads and the loctite to keep them seated. I guess I was mistaken. I've got my cams back in. Cap bolts torqued to 100 in/lbs (spec 95-113). Should I give it a little time then retorque or can I close it up?
Thanks again
Thanks again
- pstrbrc
- '81 GPz 1100 project
07 Apr 2007 11:47
BSKZ650 wrote:
Actually, all anti-seize products I've used ARE lubricant-based. In fact, the tube I'm using right now says it's an "anti-seize lubricant". I can't imagine assembling an aluminum engine without it. Now, if you're using SS bolts it's best to use a non-copper base (just look at the color- it'll be either copper colored or silver) but that's not as critical as not using any. I haven't always been a preacher, remember?are you talking about the cap bolts?
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
Elkhart, Kansas USA
- BSKZ650
07 Apr 2007 12:06
yes they are lubricant based, but they are designed to keep things from gaulding, I do use anti sieze , copper type , on the spark plugs.
I use several types of lubes and sealers when I build engines
- ronjones
07 Apr 2007 15:37
Ok, guys, thanks for the replies. After getting the cams on and torquing the bolts, I tried rotating it, to check shim clearance. Something was stuck. Removed the cams again, figued out what was wrong. Put them back together, again. Engine rotated well. Checked valve clearances. Had 2 shims in wrong place. Took cams off again, switched shims. Put cams back together. Torqued cap bolts, waited a bit, retorqued... a couple broke free on retorque, now all are around 110in/lbs. Liquid gasket on cam plugs and put the valve cover back on. Snugged down the bolts but haven't torqued them to specs. Temps have been pretty cold here, the last few days. Does anyone have any thoughts on wether I should finish torqueing the valve cover to spec or would it be a good idea to let the bike set overnight and retorque the cap bolts? I'm a bit worried about the expansion differential between the stainless steel bolts and aluminum head. I don't really want to put everything back together and then have to take it back apart to retighten the cap bolts.
Thanks
Thanks
- wireman
07 Apr 2007 16:09
the bolts shouldnt be stainless unless you installed them,stainless bolts actually arent that strong.id definately use anti seize on any bolt going into aluminum
- ronjones
07 Apr 2007 16:53
wireman wrote:
So, what are they?just steel?
Nope, they are stock. I ass-u-me-ed they were stainless :blush:the bolts shouldnt be stainless unless you installed them,stainless bolts actually arent that strong.id definately use anti seize on any bolt going into aluminum
- wireman
- Duck
- e vica na i sau na ga
07 Apr 2007 18:08
1) Chase threads to a turn more than length of cap bolt beyond cap.
2) NO THREADLOCK! NO NO NO There is very little clearance between the cover and the bolts and it will keep them from backing out and you'll hear it if they get loose.
3) I'm using anti-seize but didn't see anything in the manual about it.
4) Clamp cam in place before installing caps or at least, install the bolts that will have most of their threads engaged FIRST until they start to pull the camshaft down a little. Put the others in but if you don't have at least 3 good turns, don't go much beyond finger tight.
-Duck
-Duck
