kz650 Oil cooler install
- bandit340
Re: kz650 Oil cooler install
12 Mar 2007 13:52Please Log in or Create an account to join the conversation.
- guitargeek
12 Mar 2007 16:13
bandit340 wrote:
So the kit came with the fitting to tap into the back of the oil pan?
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- bandit340
12 Mar 2007 17:50
The kit came with fittings for it.Ck the link I posted for alternate fittings
- guitargeek
12 Mar 2007 18:09
Oh yeah, I've known for some time exactly what that fitting looks like, hahaha! You can get 'em from Klasmo or American Classix, but of course I want to either find one cheap or make my own...
- 77KZ650
12 Mar 2007 19:09
the banjo fitting is easy, they are everywhere, but the return fitting is pretty much made of unobtainium:P
From looking at it, it looks like it just restricts oil flow so it has time to actually cool off in the cooler. why couldnt someone just drill the stock plug part way, thread the hole(pipe thread), and drill a small hole the rest of the way. thread a regular pipe end into it attached to the return line and it should work the same right? Im thinking about trying this instead of making the fittings shown
07 MDP Rookie of the Year
- Bluemeanie
12 Mar 2007 19:28
Bandit, you can wrap them on with thin masking tape (one wrap)it will just burn and fall off or you can also (thanks to someone here on KZR)use rubber band on each pipe with same results. P.S. love the 340, built? aqnd how do you keep your frame so shiny?
Post edited by: Bluemeanie, at: 2007/03/12 22:30
- guitargeek
12 Mar 2007 20:03
77KZ650 wrote:
Actually, no. The special fitting stops one oil passage and diverts the flow from another passage to the cooler.
- steell
12 Mar 2007 20:23
Why not do it the easy way and just use the GPz750 oil pan??
They must be pretty common, since I have 3 or 4
- RetroRiceRocketRider
12 Mar 2007 21:00
steell wrote:
Agreed!
I have that set up mounted on my ZN700. It works great, and looks like it's OEM from Ma Kaw!
I'm just waiting for two o-rings that I special ordered to show up and will also have the same set up mounted on my KZ650 too.
Agreed!
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- 77KZ650
13 Mar 2007 05:54
steell wrote:
Well I can never find any.... searched ebay a thousand times. want to sell one?:whistle:Why not do it the easy way and just use the GPz750 oil pan??
- N0NB
- Blue handles better
13 Mar 2007 06:11
So, is there some sort of thermostat built into this? I would think that until the oil temperature reaches 220 deg F or higher, that it shouldn't be routed through the cooler otherwise condensation won't be evaporated.
Just a thought.
Just a thought.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- 77KZ650
13 Mar 2007 06:18
N0NB wrote:
you have a good point, some kits do have a thermostat, but higher output motors make a lot more heat, so they would get up to temp faster than a stock bike not movingSo, is there some sort of thermostat built into this? I would think that until the oil temperature reaches 220 deg F or higher, that it shouldn't be routed through the cooler otherwise condensation won't be evaporated.
Just a thought.
