I love new cams!!
  • Bdog
  • Bdog's Avatar Topic Author
  • Sweep the leg johnny!!!
I love new cams!!
10 Mar 2007 04:47
#118875
These gpz750 are absolutely great. they really come alive after 6000 or so. The low end is a little off, but considering, it isn't that bad. I will have to post the dyno results when I can get it to the shop. I'm not expecting much but the difference in how the motor revs is staggering. What a wonderfully cheap hop-up part. Now I just need these GSXR carbs to work and I will have a real beast on my hands!!!
Bdog:woohoo:
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
  • Bdog
Re: I love new cams!!
10 Mar 2007 06:24
#118897
Oh, anyone want a set of kz750 cams? I have a set gathering dust.
Bdog
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
  • 77KZ650
  • 77KZ650's Avatar
10 Mar 2007 23:19
#119147
to all the 650 guys, kz750 cams are an upgrade to the 650, and the gpz cams are even better but they dont have the worm gear for the tach;)
07 MDP Rookie of the Year
  • MadMac74
  • MadMac74's Avatar
09 Apr 2007 15:42
#128179
:)Thanks ... I was actually wondering that. The KZ 750 came still have the worm gear ,right?
MAC:woohoo:
'78 KZ650 C2,810 conversion,stock kz 750 cams,with a Blueprinted Head both from a '81 KZ 750. BS 34 Mikunis, Mac /Kerker 4 into 1 with custom 2" comp baffle. 3 rd owner
'02 ZRX1200R, 3rd owner
'83 XR200R, 3 rd owner
'84 V65 Sabre 3 rd owner
  • KaZooCruiser
  • KaZooCruiser's Avatar
09 Apr 2007 15:50
#128184
What's the difference, if you know, or is there a link that you can post if this is a lot of information?
  • kawsakiman
  • kawsakiman's Avatar
09 Apr 2007 16:10
#128198
the gpz cams have .354 lift to them.
i bought a set off e-bay then a set of andrews with .350 came up and they still have the tach drive so i just had to have them.
when my rings get delivered, i'm hoping the 784 kit,andrews cams and a maxi-x pipe combo i got going will be all that i hope it will be.
i'm to poor to affodr great carbs so i'm going to be running 26's for now.
sorry for the hijack but anyone got a suggestion on jetting for this combo?
  • kxhonda
  • kxhonda's Avatar
18 Apr 2007 11:40
#131559
Bdog
Would you happen to still have these laying around?
1977 Kz650B1 #576th made.
Warsaw, In
  • cottoncandyninja
  • cottoncandyninja's Avatar
18 Apr 2007 12:00
#131570
ill sell you mine if you want em. im in the process of doing the exact same swap.
