Valve shimming
  • letthegoodtimesroll
  • letthegoodtimesroll's Avatar Topic Author
Valve shimming
04 Dec 2005 17:42
#11793
How much will your valve clearance change after hand lapping your valves (approx)?
1977 KZ650C1, Kerker Header, Dyna ignition and coils, GPZ 750 oil pan and cooler
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
Re: Valve shimming
05 Dec 2005 02:12
#11821
Clearance should decrease by 2 * cosine of the angle between the valve stem and the contact annulus multiplied by the increase in the width of the annulus caused by lapping. For example if it's a 45 degree cut valve and you lap an increase of 0.02mm the clearance will decrease by 0.02mm*2*0.707 = 0.028mm
Using max minus min recommended width of the seal will give you the max variation.
It's more handy to use change in clearance to tell how much you've lapped than the other way around.
It's easier to just lap and then measure the new clearance.
-Duck
Post edited by: Duck, at: 2005/12/05 05:14
  • Garn
  • Garn's Avatar
Re: Valve shimming
06 Dec 2005 01:37
#11968
Let'roll, I agree with Duck, regarding "measure after the event"!
The thing to watch if you are doing a valve-grind is that:
You probably have had the the valves machine ground and "tipped" intially. In this case, the "tipping" facing process, where they (supposedly) just take a "lick" off the opposite end of the valve, can cause the biggest alteration of clearance.
In summary the valve face grinding reduces the clearance and the valve "tipping" increases the clearance. Too much grinding at the tip can interfere with the collet/ bucket clearance.
RegardZ
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Valve shimming
06 Dec 2005 12:36
#12039
Personal observation... I have found that if you lap properly, you won't change the clearance much at all... maybe one shim size smaller shim needed. That is only .05mm... This is only if you don't have a valve job done... only lap to seal things up. Don't lap too long... most folks tend to feel more is better.
