Engine Forum
Engine forum is a tech forum for "Engine" topics.
electrolysis removes rust! (dunno about hair)
  • pstrbrc
  • pstrbrc's Avatar Topic Author
  • '81 GPz 1100 project
19 Feb 2007 15:25
#113632
Left the office early this afternoon 'cause the weather was so nice I couldn't waste it. Stopped by the hardware store for some 1/4" bolts, nuts and washers, a couple feet of 12ga solid core wire, and a 20' length of 5/8 rebar. Cut the rebar down to 2' lengths, grabbed an extra 30 gallon plastic drum I had out back, drilled some holes, grabbed my battery charger, and voila!!
Here's the set-up with one of my exhaust downpipes in it.
Here's what the before and after looks like after 2 hours.
Cool, huh? Can't wait to find out how it works removing paint from aluminum!
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
  • drayman86
  • drayman86's Avatar
Re: electrolysis removes rust! (dunno about hair)
19 Feb 2007 16:11
#113652
What's in the solution? Must be some type of acid, maybe HCl?
  • BSKZ650
  • BSKZ650's Avatar
19 Feb 2007 16:20
#113654
looks good, you know you are going to have to share on the top secret solution
77 ltd1000, current rider
76 kz900, just waiting
  • pstrbrc
19 Feb 2007 16:24
#113655
Oh, no! That's the best part. 2 pounds of baking soda for 10 gallons of water. Every web site that had info on this recommends washing soda (sodium carbonate) and say baking soda (sodium bicarbonate) is second-best, but in this little podunk town 100 miles past Nowhere, they ain't heerd'a that. 'Couse, in this little town, you should have seen the looks I got when I bought the rebar! They knew that I wasn't doing concrete, 'cause I hadn't bought any from them! So, I explained what I was doing. THEN I got some looks! :woohoo: :woohoo: :woohoo: :woohoo:
The best part about this solution is that it is completely nontoxic. Legal to dump in the gutter. EPA approved! Oh, by the way, got another downpipe finished since I posted last!:woohoo: :woohoo: :woohoo: :woohoo:
Elkhart, Kansas USA
  • arobsum
  • arobsum's Avatar
19 Feb 2007 16:39
#113656
good job!! i will have to remember this!!
  • indykaw77
  • indykaw77's Avatar
19 Feb 2007 16:48
#113658
OK OK OK....lets see the techno-drawings....or step-by-step instructions. Or just draw me a picture....what can I say.....not sharpest knife in the drawer....
Kawasaki Motorcycles...because cars lean th wrong way!
  • BSKZ650
  • BSKZ650's Avatar
19 Feb 2007 16:52
#113661
thanks for the info, just watch the dump down the drain deal, I have seen a lot of things that are supposed to be safe, but until they are used then they become bad stuff, but non the less, I like the results you are getting, cant wait to see what it does to alum, see if it will clean oxidation also
  • wireman
  • wireman's Avatar
19 Feb 2007 18:23
#113696
do you have to bake the parts afterwards to dry out the stuff that gets trapped in tight spots to keep it from causing damage later?ive had problems before with car body parts ive had stripped that will blister later you dont get every corner completely flushed out.;)
  • tganek
  • tganek's Avatar
19 Feb 2007 19:14
#113709
rust sucks
Thanks for the pics Preacher Sir! Cool to see it in action.
stupid link
Post edited by: tganek, at: 2007/02/19 22:15
  • pstrbrc
19 Feb 2007 19:39
#113726
A cheap Harbor Freight heat gun is what I'm using. Just keep heating the part until it quits steaming. It's just my first day, but so far, so good!
Elkhart, Kansas USA
  • caffcruiser
  • caffcruiser's Avatar
19 Feb 2007 19:59
#113733
The solution IS completely safe to dump in the yard. It's just baking soda and iron basically. It may not be good for grass as it's very iron rich though, so dump it somewhere that doesn't matter.
BUT DO BE CAREFUL WHILE YOU ARE DOING THIS!!!!
All those little bubbles that you see coming off of the part and "foaming" on the water? Well, those bubbles are part of the byproduct of this procedure.... and they are filled with Hydrogen.
HYDROGEN PLUS SPARK/FLAME = BOOM.
Make sure to have plenty of ventilation in the area you are using to work.
Have fun! :)
  • RespectTheTeg
  • RespectTheTeg's Avatar
20 Feb 2007 04:07
#113785
Not just hydrogen but pure oxygen as well!! Bigger boom!!
Your breaking down the bonds between the H2 and the O. So do this outside not in the garage. And keep heat and flame away!!
I think I may do this to clean up my kerker!!
Sweetness!!
