Got pics...?
- indykaw77
Got pics...?
11 Feb 2007 19:46
...preferably close ones, of a V&H 4-1 where the collector meets the muffler?? Have cut the bad bent section out and got some welding done....but need pics to see if the collector is "centered" where the pipes meet, or offset for clearance, or what. Ad pics arent much help. Thanks in advance.....mods feel free to move if this is wrong forum.....
Kawasaki Motorcycles...because cars lean th wrong way!
- steell
Re: Got pics...?
11 Feb 2007 20:12
Where would we move it to??
Besides that I want to see pics of what you are doing, and how it looks when you are finished
- KZ250LTD
Last edit: 26 Aug 2009 11:13 by KZ250LTD.
- indykaw77
Re: Got pics...?
12 Feb 2007 04:24
steell wrote:
Its rough looking right now...just tacked here and there until I KNOW if the collector is centered....that being said, once its all together (and it doesnt look like *ss!), will throw up some pics. Hmm.....maybe shoulda said will post some pics......
- indykaw77
Re: Got pics...?(update)
12 Feb 2007 11:19
Well....slow going but this what i got after about 4 tries so far. LOTS of re-cutting, re-measuring, and eyeballing for fit. But heck, 'twas easy ANYBODY could do it....right? Keep in mind pieces are just TACKED and not ready for the "pretty-test"....
- indykaw77
12 Feb 2007 11:20
- guitargeek
12 Feb 2007 13:45
Seems like the most common way to make a collector would be to use a large cone-shaped piece and crimp it down to fit around the pipes, and a +
shaped piece to go between them.
Very expensive racing systems use four identical pipes, bend them all the same, cut them all to fit, then weld the pieces together:
If I were in your shoes I'd probably go the easy route and make it a 4 into 2 into 1 system using three Y connectors.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- guitargeek
12 Feb 2007 13:51
- guitargeek
12 Feb 2007 13:59
- indykaw77
12 Feb 2007 14:22
1st choice was to cobble up another collector....but couldnt find at local bike boneyard...
Thought of the "wrap pipes in sheetmetal" approach....but no way to heat metal and hammer into submission. Hesitant to use anything thin enough to form just by hand....thoughts on that, anyone? The ones on the website look pretty cool and JUST what i need....am gonna investigate prices.....thanks for that heads-up.
I look at it this way...if nothing else...is good cut/fit/weld practice........:whistle:
Post edited by: indykaw77, at: 2007/02/12 17:24
- pstrbrc
- '81 GPz 1100 project
12 Feb 2007 15:45
If you are looking for a collector...
www.stans-headers.com/parts.htm
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
Elkhart, Kansas USA
- indykaw77
12 Feb 2007 17:09
By jove, I think we've got it. Now to measure tube size......TO THE BATCAVE!
