Cylinder De-glazing Tool
  • Mcdroid
  • Mcdroid's Avatar Topic Author
  • Gone Kwackers
11 Feb 2007 15:58
#111619
Hello Folks:
Just bought a Lisle Cylinder De-glazing Tool and I understand how to use it. However, what type of oil (if any) should I be using while de-glazing the cylinders?
Post edited by: Mcdroid, at: 2007/02/11 18:59
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • kzwolfsr
  • kzwolfsr's Avatar
Re: Cylinder De-glazing Tool
11 Feb 2007 16:06
#111627
Look up honing on here and you might find it. Some people use engine oil, I would use three in one oil.
Original man of the Caribbean
  • BSKZ650
  • BSKZ650's Avatar
11 Feb 2007 16:35
#111639
honing oil is the best, but for the samll amount that you will be using, it may be too expensive.
you can use kerosene, it is light enough but you have to keep it flowing, the main idea is to keep the honed material away from the work, hone stone and cyl wall,
I used to use a empty soap bottle, fill it with the fluid, and keep applying it while you hone.
I dont remember , but is this the one that is spring loaded?
77 ltd1000, current rider
76 kz900, just waiting
  • Mcdroid
  • Gone Kwackers
12 Feb 2007 02:04
#111752
Thanks...and yes, it is spring loaded.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • BSKZ650
  • BSKZ650's Avatar
12 Feb 2007 05:12
#111770
just realized you are not too far from me, if you need some help let me know
  • Mcdroid
  • Gone Kwackers
12 Feb 2007 05:32
#111775
Thanks for the offer...but let me really screw it up first before I ask for help:laugh: :laugh: :laugh:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • KaZooCruiser
  • KaZooCruiser's Avatar
12 Feb 2007 10:54
#111843
Marvel Mystery Oil, PB Blaster, ATF, sewing maching oil, Diesal fuel/Kerosine. . .anything to float off the debris as you are working the hone. Eventually, you want a cross-hatch pattern at about 30 degrees. My machinist friend says about 50 strokes with a dingle-berry hone does a pretty good job on the stuff he does.
When you are done, use hot soapy water (dishsoap) and a brush to flush all the honed surfaces to remove metal filings and grit from the honed surfaces. A circular toilet brush does a great job to help the scubby bubbles. Dry it off and shoot it down with some oil to prevent corrosion.
  • Mcdroid
  • Gone Kwackers
12 Feb 2007 11:30
#111854
More good advice...thanks KZC:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • trianglelaguna
  • trianglelaguna's Avatar
16 Jan 2009 09:47 - 16 Jan 2009 09:49
#258239
i am waiting on a ring set(one cyl) in the mail and am gonna put the 71mm piston in their jugs and slide the block on(that will be a proccess for a guy like me)lol....now do i need to re-hone each jug or can i just do the jug with the new ring set.....the shop here transferd me to parts when i asked if they could hone a cyl for me and they sounded dumber than i am believe it or not:cheer: ...can i buy a dingleberry hone tool cheap and do it myself ..i did a few twenty years ago.. ????what size do i get??? ...who can you recomend to buy one from????...thanks...craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 16 Jan 2009 09:49 by trianglelaguna.
  • PLUMMEN
  • PLUMMEN's Avatar
16 Jan 2009 10:04
#258244
youre only putting rings in the 1 cylinder,is there more thanone on the motor your fixing?:blink:
  • trianglelaguna
16 Jan 2009 10:19
#258247
yes there are four and wiseco and finances said i could just replace the one set that had a dammaged ring..the others are o.k...there are no marks or stipes on the cyl walls and the motor had great comp when this block and piston set was removed...i bought the set used ,,,cheap... and allready had a complete rebuild gasket kit and the 73 z-1 motor that was rust seized..and pulled the old trash block and 903 pistons.... and amready to put 71mm block and pistons on...i am being cheap but this is all extra stuff i had and am pretty sure it will be o.k...just wanted some advicePLUMMEN wrote:
1976 KZ900
2003 ZX12R
2007 FZ1000
  • trianglelaguna
16 Jan 2009 10:45 - 16 Jan 2009 11:17
#258249
i was hoping i could get some help from the folks that seem more exp...this is a bunch of years old parts -barn find- some junked.... that i have a lot of... and wanna combine into a running motor...i would then be able to as my work picks up.. pull my current in bike running motor and explore what kind of correct procedures and all new parts rebuild i want for a nice motor for my ride...and just want an answer to my cylinder hone questions a few posts back thanks... b]PLUMMEN wrote:[/b]
1976 KZ900
2003 ZX12R
2007 FZ1000
Last edit: 16 Jan 2009 11:17 by trianglelaguna.
