Rechrome Z-1 Classic engine covers
- baja454
27 Jan 2007 09:50
Since I can't seem to find good condition chrome engine and chain covers, has anyone had luck with rechroming them? Who would you recomend to have them done by?
- edspring1
Re: Rechrome Z-1 Classic engine covers
27 Jan 2007 10:25
i use chromemasters. i think they are in TN.
they do have a web page but i can not remember the upper & lower cases to pull them up. i have used just about everyone. they are the best. their stuff lasts for years and years. NO BULL ! Just remember...anything you have plated that has threaded holes...re-tap them before installation, and pay special attention to ALL gasket surfaces!
Good Luck!
Good Luck!
- austin3119
27 Jan 2007 10:45
Have you considered having them polished or doing it yourself. You will find a lot of different opinions on this subject, but I prefered polished parts on the older bikes. It is more work to keep up though.
Good luck in whatever you choose.
- IowaKZ
- '80 G1 Classic
27 Jan 2007 11:09
Hey Baja, I'd be interested in how this turns out if you go for it. I have a Z1 classic also and the covers are crappy. I'd also like to know the $. I am trying to go back to original condition, but this is definitly one area where I need help.
1980 G1 Classic
Bettendorf, Iowa
Bettendorf, Iowa
- btchalice
27 Jan 2007 15:39
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- CoMIYC
27 Jan 2007 19:20
To keep it clean without polish final clean the parts with laquer thinner.
Tremclad makes a clear coat product that is made especially for clean bare polished metal. Use the glossy and the parts take on a real silky chrome look that will last!
Keep your parts clean like you would the other painted surfaces.
www.birdsperformancecoatings.com
75 Z1B 1135, 83 GPz 1170, 85 RZ350, 86 RZ 350, 2000 ZX9R
Gone: 81 CB400T, 83 Kz750
AKA: Don
AKA: Don
- racer54
27 Jan 2007 23:18
Maybe I overlooked it, but I couldn't find any clear. Can you tell me which site you went to to find some?
- kz1000g
28 Jan 2007 11:09
Most of the polished engine cases from older KZ1000's will fit our bikes. The only one that won't fit is the alternator cover (ours are bigger).
Paul Sr.
kz1000g
Paul Sr.
kz1000g
- The Gringo
- ¡Usted no necesita otra motocicleta!
28 Jan 2007 12:13
kz1000g wrote:
That's an interesting little tidbit to know. Do you know if it is bigger due to increased charging capacity (ie: is the stator larger to accomodate the additional demands of the EFI)? Sounds like I need to keep my eyes open for one to hoard just in case. I would have assumed the cover was the same except for being chromed from the factory. Thanks for the info Paul.
Paul Sr.
kz1000g
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- CoMIYC
28 Jan 2007 12:46
TREMCLAD 27073B 522
bar coded: 63213 00025
phone: 1 800 387 3625
aka TREMCO
aka RPM Company
fyi: the manufacturer does
Also one other note: It goes on milky and drys crystal clear so don't panic!:woohoo:
aka TREMCO
aka RPM Company
not
AKA: Don
AKA: Don
- Dustproof
29 Jan 2007 21:45
Hi Guy's,
Has anyone tried to remove the chrome from the engine covers ? I presume some sort of wire brush or abrasive process to get it back to bare metal for polishing.
Also is there a website for the clear product to coat the parts when finished.
Thanks
Noel
Thanks
Noel
- wireman
29 Jan 2007 21:54
chemical stripping at a plating shop is the best way i know to strip chrome,then polish and wax them;)
