Jumping Time?
  • kzwolfsr
  • kzwolfsr's Avatar
Re: Jumping Time?
18 Jan 2007 06:31
#106579
No 16 in the diagram isn't really a tensioner but it puts the chain in position and it's in the cam cover, so the cover goes on first then the tensioner. Also when you think about it when you put the cover on last, the chain positioner would push the chain down on the top between the 2 cams changing timing position. Well its a good feeling to know I finally help someone on here. I just saved you a ton of work
Original man of the Caribbean
  • kawadruida
  • kawadruida's Avatar
Re: Jumping Time?
19 Jan 2007 09:32
#106809
Definitely you must put the valve cover on before final tensioner assembly. Later I will post some pics from my Clymer 550 manual showing correct pushrod alignment.
Cheers.
  • kawadruida
Re: Jumping Time?
19 Jan 2007 19:34
#106953
Here go the pics for the whole procedure.
  • kawadruida
Re: Jumping Time?
19 Jan 2007 19:35
#106954
Nº 2
  • kawadruida
Re: Jumping Time?
19 Jan 2007 19:35
#106955
Nº3
  • kawadruida
Re: Jumping Time?
19 Jan 2007 19:36
#106956
Nº4
  • kawadruida
Re: Jumping Time?
19 Jan 2007 19:36
#106958
Nº5
  • kawadruida
Re: Jumping Time?
19 Jan 2007 19:37
#106959
Nº6
Post edited by: kawadruida, at: 2007/01/19 22:38
  • kawadruida
Re: Jumping Time?
19 Jan 2007 19:37
#106961
Nº6
  • kawadruida
Re: Jumping Time?
19 Jan 2007 19:38
#106962
Nº7
  • kawadruida
Re: Jumping Time?
19 Jan 2007 19:39
#106963
Nº8 (finally, the last one...)
  • cnyl
  • cnyl's Avatar Topic Author
Re: Jumping Time?
20 Jan 2007 04:40
#106994
Wow... Thanks guys.;) Those pics are alot better in detail than the service manual that I have. I'll make another attempt sunday.
Thanks again.B)
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
