440 Turbo ?
- martijn
Re: 440 Turbo ?
06 Jan 2007 11:50
JAILBAIT wrote:
How do I modify the oilpump in case of a kz900/1000??
. Or you can go the hard way and modify the oil pump to run at a higher pressure like myself and wireman did.
- wireman
Re: 440 Turbo ?
06 Jan 2007 15:39
sanding or milling a little off the mating surface of pump halves to tighten up clearances between gears and housing is easiest way to do it;)
- duncan
Re: 440 Turbo ?
07 Jan 2007 11:12
the problems with turbocharging a small engine seem to be lubrication (discuused above) and cooling (the small garrett GT12 needs water, as well as oil).
as well, the intake cycles of a four cylinder are continuous enough to handle the continuous pressure from the t/c, but the intake cycles of a two cylinder are too lumpy, and require a surge tank to smooth out the pulsing....from an old 1984 article on turbochargin a motorcycle:
img375.imageshack.us/my.php?image=kzturbo06qo7.jpg
img174.imageshack.us/my.php?image=kzturbo07vt2.jpg
img174.imageshack.us/my.php?image=kzturbo08ht4.jpg
- guitargeek
Re: 440 Turbo ?
07 Jan 2007 12:03
A surge tank shouldn't be that hard to fabricate. I'm thinking of something like a piece of aluminum or copper pipe, say 3 or 4 inches in diameter, maybe a foot long, with a couple pipes welded onto the side to mount to the head and a cap on one end and the pressurized inlet on the other end.
As for the lubrication problem, I wonder who makes a tiny turbo unit with roller bearings instead of oil film bearings...
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- djnubz
Re: 440 Turbo ?
07 Jan 2007 13:27
I have been thinking about how to go about this myself for a while but I won't be able to get to it for some time due to me being at school. The way I would go about this would be to first modify the bike to work off of a Mega Squirt 2 setup. With this you will have complete control over the fuel and spark, which you need in a turbo application. From there I would use a very small turbo, they make some for go cart motor if you can find them.
- 50 bucks
Re: 440 Turbo ?
07 Jan 2007 18:38
Man, The things I'm findin' with the search on this idea are really gittin' wierd ! Came across a guy on a site askin' about superchargin' a Briggs lawn mower engine. Another guy suggested usin' a smog pump from a 350 Chevy.Connect it to the engine with a chain or belt. I must be gettin' punchy, but at first thought, it sounds like that would work
- steell
Re: 440 Turbo ?
07 Jan 2007 19:24
50 bucks wrote:
Oh yeah, supercharging a Briggs with a smog pump works, the motor don't last very long though
There is also at least one guy that has fuel injected a Briggs using a MegaSquirt
- 77KZ650
Re: 440 Turbo ?
07 Jan 2007 19:42
JAILBAIT wrote:
Scott
Anyone else like to comment of this point? would running oil through the water lines it help or hinder it? and with a water cooled bike, do you just connect to the rad?Also water/oil cooled turbos don't have to have the water lines connected. This is just to runthe turbo cooler.
Scott
07 MDP Rookie of the Year
- GPzephyr
Re: 440 Turbo ?
08 Jan 2007 00:58
77KZ650 wrote:
I wouldn't go down the oil route but if you really wanted to use the cooler on the turbo then rig up an independent water supply.
Get a small radiator off a scooter or something small, maybe another oil cooler would do and run it using an electric pump connected via a thermostat. Job done!
JAILBAIT wrote:Anyone else like to comment of this point? would running oil through the water lines it help or hinder it? and with a water cooled bike, do you just connect to the rad?Also water/oil cooled turbos don't have to have the water lines connected. This is just to runthe turbo cooler.
Scott
1991, Zephyr 750. GPz750 turbo engine, 810cc, Garrett T25 turbo, GPz1100 throttle bodies, 310cc injectors, Power commander, Dyna coils, Lots more as well...
KB Saturn fitted with a stock GPz750 turbo engine. Loads to do on this project.
- JAILBAIT
Re: 440 Turbo ?
08 Jan 2007 06:34
i will try to answer some of the questions if I can.
don't worry about the water side of the turbo, and if all possible find a turbo that doesn't have both water and oil cooling. with the size turbo you are most likely going to use you don't need both anyways.
there is no reason on a bike like this you would need to go to the hasle of putting a stand alone EFI system. You can easily modify a carb to blow through that will work with a lot less headache.
As for keeping things safe and cool methanol injection is the easiest. There are companys out there that make full kits or there are ways to get around putting all that electrical stuff on your bike and jjust making it machanical.
Just remember that easy part is buying all the parts. its the fabing of the exhaust manifold, intake manifold, etc, etc.
- JAILBAIT
Re: 440 Turbo ?
08 Jan 2007 06:39the problems with turbocharging a small engine seem to be lubrication (discuused above) and cooling (the small garrett GT12 needs water, as well as oil).
using a simple surge valve from like a procharger supercharger kit will work just fine. this valve is not the same as a bov, it is constintly open under normal riding, then as soon as boost comes on the valve shuts and whoa power time.
Post edited by: JAILBAIT, at: 2007/01/08 09:40
- Lorcan
- Speed Loony
Re: 440 Turbo ?
08 Jan 2007 14:07
You don't need to connect the water lines to anything. They are only there for when the turbo is used on a car - i.e. under a hood where it gets very hot. Out in the breeze on a bike you don't need any water cooling connected.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
