I need serious help!
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
Re: I need serious help!
15 Oct 2023 21:10
#890538
KellyE, I believe you. I’ve heard nothing but good things about them from owners and people who’ve ridden them. I very nearly bought one. I bought a ZZR1200 instead, which is no lightweight either. The ZZR can really boogie tho.
I have a ZZR 1200 shock on the back of my Concours and Progressive springs in the front. For a super tanker it really boogies too. My buddy says sometimes the bags are almost dragging.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
  • TheTrout
  • TheTrout's Avatar Topic Author
25 Oct 2023 11:46
#890949
So I have been eyeing a llot of other bikes.  It occurred to me that what I seek is really more range.  Has anyone ever fit a larger tank onto their KZ?  I have a 78 KZ1000b2 (LTD).  Do you think it is possible to modify a larger tank to fit my existing frame mounts?  I would love to be able to have both tanks fit the bike.  Has anyone done anything else to extend their riding range?
1978 KZ1000B2
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
25 Oct 2023 11:52
#890950
Anything is possible (almost) you just need to think outside the box   if you are brave enough you could cut up a pair of "re-pop" tanks and go twins as Harley do on some models ? How's your welding
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
25 Oct 2023 13:48
#890956
I’ve taken some long trips and even though my range was easily over 200 miles I found myself topping off at about 125 miles just so I could get off the bike and stretch my legs.
If your KZ gets poor mpg there are ways to improve it. My KZP got low 30’s mpg and it only has a four gallon tank. I rejetted and did a gear change and managed to improve the mileage to 45 mpg.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
25 Oct 2023 15:09 - 25 Oct 2023 15:13
#890958
Another vote for the FJR. Mine is the '16 ES version so the desirable 6th gear OD, heated grips, cruise control, and electronic suspension. All day (and I mean 12-14 hours) comfort and claw hammer like reliability.
True story: My little brother got a Harley something or other and was bragging about Screaming Eagle this and Screaming Eagle that. When we finally lined up at a stop light it wasn't even close. I shut it down at 100+ and still in 3rd gear. He stopped bragging after that
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Last edit: 25 Oct 2023 15:13 by ThatGPzGuy.
  • TexasKZ
  • TexasKZ's Avatar
25 Oct 2023 15:15 - 25 Oct 2023 15:16
#890959
A lot of Iron Butt riders use an auxiliary fuel tank, often strapped to the passenger seat.
With good fabrication skills, you could adapt most any tank. So far as I know, the largest one Kawasaki ever made was for the Concours 1000. It was 7.5 gallons. The mounts are different from the KZ and you may experience interference with the handlebar.
The tank from the KZ1000J may be a close fit.
Last edit: 25 Oct 2023 15:16 by TexasKZ.
  • TheTrout
26 Oct 2023 04:31
#890972
My bike gets about 45 mpg.  I try to get gas at 90 miles, at 100 miles my butt puckers, at 110 miles I am pushing the bike.....ask me how I know.
1978 KZ1000B2
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
26 Oct 2023 05:31
#890973
Maybe a "P" tank is the easiest answer ??
  • Moose1800
  • Moose1800's Avatar
26 Oct 2023 09:06
#890982
A Z1/KZ tank should fit the frame on your LTD about the only difference is the petcock bung on the LTD is about an inch or so closer to the carbs/engine than on the full size tank found on the Z1/KZ, but you may have clearance issue with the petcock/side cover.
  • hardrockminer
  • hardrockminer's Avatar
26 Oct 2023 19:32
#890992
Yes, a Z1 or KZ tank will fit on an LTD model.  From memory the LTD tank is about 13 liters.  I can't recall the size of the regular tank.  Your range is about the same as mine on my LTD.  My Z1 will go farther, but as you point out Kawasaki's weak point was their seat.
When you ran out of fuel did you know that there is still a half liter or more normally trapped on the right hand side of the tank?  I ran out on my LTD, so I took the tank off and allowed the trapped fuel to run to the petcock side and was able to ride to a gas station.
  • sf4t7
  • sf4t7's Avatar
26 Oct 2023 20:08
#890993
The regular Z1 tank is about 4 3/4 gallons.  Just happened to look it up the other day.
And thanks HRM, I've wondered about the right side of the tank after turning to reserve and looking for the next gas station.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • TheTrout
27 Oct 2023 03:14 - 27 Oct 2023 03:21
#890999
I have a pingle petcock, no reserve.  I did not know about the 1/2 litre stuck on the right side.  Anyone have a Z1 tank they want to get rid of?  I imagine they are not an easy find.  Having over 4 gallons and doubling my range would be awesome!
I found a guy that has a small lot of gas tanks, all makes.  I see a couple of Kawasaki tanks in there.  How can I tell if any of them are Z1 tanks?
1978 KZ1000B2
Last edit: 27 Oct 2023 03:21 by TheTrout.
