seat compatible transfer
  • damon
  • damon's Avatar Topic Author
27 Nov 2019 14:45
#814667
I need to know if a seat from a kz750 b twin will fit on a 1980 kz750 g1 twin, I want to get rid of the g1 step seat and go with b era bench. . are the seat pan and hardware a direct fit? or will there have to be some fabrication?
  • martin_csr
  • martin_csr's Avatar
Re: seat compatible transfer
28 Nov 2019 02:10 - 29 Nov 2019 05:08
#814673
I did a search & found this reply by steell: It is a direct swap, I had an 80 750G seat on my 79 750B, ....
If the swap works one way, then it should work the other. steel probably knows more about the 750 Twins than just about anybody around, so whenever you see any of his replies, your ears should perk up. also, Bountyhunter knows quite a bit about the big Twins.
kzrider.com/forum/6-paint-a-bodywork/517...options-for-79-kz750
From the diagram drawings at Partzilla & EB photos, they look the same & appear to have the same mounting hardware.
I didn't compare part numbers, but you can x-ref the parts & compare EB pics. or just follow steell's advice.
Last edit: 29 Nov 2019 05:08 by martin_csr.
  • damon
28 Nov 2019 06:57
#814675
thank you martin and all others, you been a great help enjoy your thanksgiving holiday and weekend
