I'm so sorry
  • shamal
  • shamal's Avatar Topic Author
I'm so sorry
18 Jun 2019 01:41
#805976
i have to start a new 3d about that but im really astumped and i need help.
GPZ900R , bike is running PERFECT. easy start, perfect idle, alot of power in the entire power band of the FIRST FOUR GEARS, but when is in 5th or in 6th gear she wont go over 7000 rpm. just stop climbing rpm, just sitting there and nothing.
i have tried in the last months:
swapped coils
swapped pick up coils
swapped cdi box
different sets of plugs
new plugs caps
a good condition used alternator assembly.
bypassed lockout switches (clutch and kickstand)
tried differetn fuel
tried to use the choke under heavy load in 5 and 6 gear..(no way)
tried to running with opened gas cap
new air filter
cleaned airbox
new intake boots NOS
the engine can redline in 1, 2, 3, 4 very easily and it is FAST! 140 rpm in fourth gear is so easy..
i cleaned the carburetors million times and i ve tried another set of carbs from another bike, still no joy.
compression is a good 150 psi and carbs was synched recently.
the bike is totally stock and is only missing the centre tube between the silencers under the bike (the PO for some reason cut and weld it)
please HELP ME
1983 kz 550 h
  • Irish Yobbo
  • Irish Yobbo's Avatar
Re: I'm so sorry
18 Jun 2019 03:50
#805978
Unless you're tracking it, performance above 7000rpm in 5th gear shouldn't be a problem.
Compression at 150 sounds pretty low to me - if all the cylinders are the same then it will run fine, but you can't expect the same performance as new. Every compression gauge reads different, but for full power in the top gears I would expect to see above 180psi in a new-condition engine, since it's a fairly high compression ratio. But check your manual for expected values.
1981 KZ750 LTD
  • martin_csr
  • martin_csr's Avatar
Re: I'm so sorry
18 Jun 2019 06:13 - 18 Jun 2019 06:14
#805984
I"d be wondering about the lack of a crossover, which seems like that would be a pretty significant modification of the muffler system. Eliminating the crossover reduces the exhaust cross-section by about half or thereabout & I would assume increase the back pressure by quite a bit. There was a topic w a link here on KZR about exhaust system physics, but the last time I checked the link was gone. Unrelated to the mufflers, I would make sure the battery is good >> charge it with a good motorcycle smart charger & do a load test. I don't think this is your problem, but checking the battery is easy & should be done anyway.
Last edit: 18 Jun 2019 06:14 by martin_csr.
  • loudhvx
  • loudhvx's Avatar
Re: I'm so sorry
18 Jun 2019 06:37 - 18 Jun 2019 06:38
#805986
You didn't mention anything related to fuel flow in your list.
Do you have an inline fuel filter? If yes, make sure it is not a paper element for cars. They restrict flow over time.
Make sure the fuel line pours fuel out fast.
Last edit: 18 Jun 2019 06:38 by loudhvx.
  • Nessism
  • Nessism's Avatar
Re: I'm so sorry
18 Jun 2019 07:20
#805993
You might be expecting too much from the bike. I'm not sure how much speed you can expect past 140 mph. Anyway, since it's not mentioned I'd be sure to catch up on all the maintenance such as valve clearances.
  • bluej58
  • bluej58's Avatar
Re: I'm so sorry
18 Jun 2019 07:59
#805999
I hope you have good tires.......
78 KZ1000 A2A
  • loudhvx
  • loudhvx's Avatar
Re: I'm so sorry
18 Jun 2019 08:05
#806000
Did he really mean 140 mph? He wrote "140 rpm" so maybe he means 14000 rpm? He seems to be speaking in rpm rather than mph, but I guess 14000 rpm would be awfully over-revved.
The following user(s) said Thank You: shamal
  • shamal
Re: I'm so sorry
18 Jun 2019 10:05
#806008
Nono, i mean 140 mph and the bike stop at 7000 rpm in 5 and 6 gear. I have valve clerance checked and registered and this problem will make me crazy..
Battery is new and charged but i have swapped the battery also from another bike.
I have a inline fuel filter, no paper element and the fuel flow is good!
I was wondering if the problem can be in the red stop switch button maybe?
I dont think im expecting too much from the bike because other 900r i have tried go past 7000 rpm easily in 5 amd 6 gear
1983 kz 550 h
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: I'm so sorry
18 Jun 2019 13:22
#806020
The GPZ900R max. Speed is round about 250 Km/h = 155 mph under optimal conditions with a single driver!!!
You shamal do 140 mph in 4th gear!!! Sound like you drive with the wrong front/rear sprocket setup (secondary gear ratio)???
GPZ900R front/rear sprockets 17/49(50) = 2,88 to 1
GPZ1000R(X) front/rear sprockets 15/40(41) = 2,66 to 1
Just a thought...
  • shamal
Re: I'm so sorry
18 Jun 2019 14:08
#806027
No i have a new did set 17/49.. I really dont know what can i do. Its very frustrating on the highway hitting the 7000 rpm limit..
1983 kz 550 h
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: I'm so sorry
18 Jun 2019 14:26 - 18 Jun 2019 14:29
#806028
So if you shift from 4th (150 mph) into 5th gear the bike slows/revs down to 7000 rpm???
In 4th (150 mph) how many revs are on the speedo (rev meter)?
Are both wheels Spinning freely???
Last edit: 18 Jun 2019 14:29 by Scirocco.
  • shamal
Re: I'm so sorry
18 Jun 2019 15:08
#806031
Yes. The bike is just unable to rev past 7000 rpm in 5 and 6 gear. Is no acting strange, just stop climbing rpm, and the engine should pull at least more + 3000 rpm.. As it does in the other gears
1983 kz 550 h
