Sealant storage to keep contents in tube from hardening
  • martin_csr
  • martin_csr's Avatar Topic Author
29 Oct 2018 13:25
#793031
Has anyone tried vaseline to store their sealants to prevent them from hardening?
I saw this storage tip video for gasket makers & rtv.
  • Nessism
  • Nessism's Avatar
  • Away
Re: Sealant storage to keep contents in tube from hardening
29 Oct 2018 15:40
#793046
I don't like it. The vaseline will contaminate the sealant. You would have to squeeze off a goodly portion of sealant in order to be sure no vaseline is present before you could use the sealant. Seems needlessly fiddly. If the sealant has hardened up on the end you can drill down to create a path to the soft stuff...or throw the tube away since it's no doubt way past it's expiration date anyway.
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Oct 2018 15:56
#793047
I just use a bolt. This tube is two years old. Just used it yesterday. B)
