Bike port
Re: Bike port
17 Mar 2022 13:01
- daveo
Re: Bike port
18 Mar 2022 01:29 - 18 Mar 2022 11:02
Steve, I would like your opinion on the color of my plugs...
This is with one-step colder spark plugs, and the RS34 flat slide carbs which will probably stay on the bike for a while.
Have 27.5 pilot jets installed for the mid-40's to 60's air temps currently in W. Michigan. Will probably drop to 25's when warmer weather arrives.
I'm going to attempt a short ride video with my cell phone camera if I can make that work.
1982 KZ1100-A2
Last edit: 18 Mar 2022 11:02 by daveo.
Re: Bike port
18 Mar 2022 07:27
Try hotter plugs?
Re: Bike port
18 Mar 2022 07:33
My $.02. They look about as good as your going to get. Dry black full circle on the base ring. Nice tan color on the center ceramic. And a color change on the earth strap in the correct spot… Ride it like you stole it!
My only suggestion is to get a magnifying glass and look down inside at the bottom of the ceramic and look for shiny specs. It would indicate detention, if present it actually microscopic pieces of the piston getting exploded off.
Re: Bike port
18 Mar 2022 07:39
Mine looked like that at first. The more miles I put on the new bores the better the plugs look.
- daveo
Re: Bike port
18 Mar 2022 10:28My $.02. They look about as good as your going to get. Dry black full circle on the base ring. Nice tan color on the center ceramic. And a color change on the earth strap in the correct spot… Ride it like you stole it!
Didn't see that strap color with the standard hotter plugs...thank you zed1015 for the spark plug heat range recommendation.
The ceramic had consistent color from top to bottom, with no aluminum specks visible way down in there. While I was cleaning carbon off the pistons recently, I saw no evidence of detonation on those surfaces either.
Thanks again
1982 KZ1100-A2
Re: Bike port
18 Mar 2022 11:13 - 18 Mar 2022 11:15
Chances are the heat range was to hot and the color on the earth strap was either not changing or it was right at the base ring. Either way you wouldn’t see it!
Here’s a good reference.
www.dragstuff.com/techarticles/how-to-read-plugs.html
Last edit: 18 Mar 2022 11:15 by Mikaw.
Re: Bike port
19 Mar 2022 13:19
Re: Bike port
20 Mar 2022 11:27
I ordered a set of bearings last night. I'll use these to balance the tire then change them when they come.
Re: Bike port
20 Mar 2022 14:47
Re: Bike port
20 Mar 2022 18:07
Is there a casting number on the crush drive. It looks similar to the one Mr E was looking for that fits a 77-78 rear spoke with disc
Re: Bike port
20 Mar 2022 19:00
If there is it's not legible. There was a ink number followed by a cast one but the ink came off when I tried to clean it. It is smaller that my Z1/KZ900 sprocket carrier.
