- Thank you received: 2739
Bike port
17 Mar 2022 13:01 #863932
by SWest
Replied by SWest on topic Bike port
- daveo
- Thank you received: 654
18 Mar 2022 01:29 - 18 Mar 2022 11:02 #863957
by daveo
1982 KZ1100-A2
Replied by daveo on topic Bike port
Steve, I would like your opinion on the color of my plugs...
This is with one-step colder spark plugs, and the RS34 flat slide carbs which will probably stay on the bike for a while.
Have 27.5 pilot jets installed for the mid-40's to 60's air temps currently in W. Michigan. Will probably drop to 25's when warmer weather arrives.
I'm going to attempt a short ride video with my cell phone camera if I can make that work.
1982 KZ1100-A2
Last edit: 18 Mar 2022 11:02 by daveo.
18 Mar 2022 07:27 #863968
by SWest
Try hotter plugs?
- Thank you received: 1918
18 Mar 2022 07:33 #863969
by Mikaw
Replied by Mikaw on topic Bike port
My $.02. They look about as good as your going to get. Dry black full circle on the base ring. Nice tan color on the center ceramic. And a color change on the earth strap in the correct spot… Ride it like you stole it!
My only suggestion is to get a magnifying glass and look down inside at the bottom of the ceramic and look for shiny specs. It would indicate detention, if present it actually microscopic pieces of the piston getting exploded off.
18 Mar 2022 07:39 #863970
by SWest
Mine looked like that at first. The more miles I put on the new bores the better the plugs look.
- daveo
18 Mar 2022 10:28 #863984
by daveo
Didn't see that strap color with the standard hotter plugs...thank you zed1015 for the spark plug heat range recommendation.
The ceramic had consistent color from top to bottom, with no aluminum specks visible way down in there. While I was cleaning carbon off the pistons recently, I saw no evidence of detonation on those surfaces either.
Thanks again
1982 KZ1100-A2
Thanks again
1982 KZ1100-A2
18 Mar 2022 11:13 - 18 Mar 2022 11:15 #863989
by Mikaw
Chances are the heat range was to hot and the color on the earth strap was either not changing or it was right at the base ring. Either way you wouldn’t see it!
Here’s a good reference.
www.dragstuff.com/techarticles/how-to-read-plugs.html
Last edit: 18 Mar 2022 11:15 by Mikaw.
19 Mar 2022 13:19 #864041
by SWest
20 Mar 2022 11:27 #864087
by SWest
I ordered a set of bearings last night. I'll use these to balance the tire then change them when they come.
20 Mar 2022 14:47 #864094
by SWest
20 Mar 2022 18:07 #864103
by Mikaw
Is there a casting number on the crush drive. It looks similar to the one Mr E was looking for that fits a 77-78 rear spoke with disc
20 Mar 2022 19:00 #864108
by SWest
If there is it's not legible. There was a ink number followed by a cast one but the ink came off when I tried to clean it. It is smaller that my Z1/KZ900 sprocket carrier.
